20 Most Recent Jump Start JUMPSTART ADVANCED 1ST GRADE (876930000140) Questions & Answers
The Knowledge Adventure page makes this suggestion:
Recommendations:
· JumpStart: Most of the JumpStart programs have a keystroke combination like CTRL+D+D to delete one user at a time from the sign in screen. See the manual for more information regarding the software. Other JumpStart programs have a delete button directly on the sign in screen.
CTRL+D+D didn't work for me on JumpStart Kindergarten, but CTRL+ Delete did!
Jump Start... | Answered on Jun 16, 2011
Jumpstart advanced 1stgrade cd rom installation.
System Requirements
Windows: 98/ME/2000/XP; Pentium II 266MHz (Pentium II 300MHz or faster for XP); 64 MB RAM (128 MB RAM for XP); 100 MB HD; 12x CD-ROM drive; 16-Bit color; Windows compatible sound card
If you are installing on a newer OS ie Vista, or Win 7, due to software incompatibility the software might not install, or even you can install the software might no work.
You can try using the "compatibility mode" in Vista or Win 7 to install the programs as "administrator" but no guarante this will work.
Alternatively, you can get a newer version which is compatible to your Operating System.
Hope it helps.
Jump Start... | Answered on Jul 26, 2010
SEE THIS SITE AND YOU SEE IF IS OR IS NOT COMPATIBLE
http://www.smartkidssoftware.com/0J.htm
SERGIO
Jump Start... | Answered on Jul 02, 2009
it may be because your system is satisfying only the basic requirements to support the game
see the system requiements for the game to run from the readme file or upgrade your system to a latest configuration
i said it because these problems occour commonly to old pc's
Jump Start... | Answered on May 21, 2009
xxxthis is a test, do not reply
Jump Start... | Answered on May 19, 2009
try right clicking on the icon and hit properties the click on the compatibility tab and select windows xp send me a comment to let me know if this helped
Jump Start... | Answered on Dec 26, 2010
You can try to use RecoveryFix for BKF recovery software to restore your deleted file. For more details you can downlaod this software: http://www.bkfrestore.org/download-free.html
http://msbkfrecovery.blogspot.com/2012/08/get-access-to-your-corrupt-or-damaged.html
Computers &... | Answered 1 hour ago
Yes it can be possible for your internet and wifi to have someone hack it then you would have to call up Shaw and contract Shaw about it and have it be fixed then or whichever interand wifi service provider that you use and have then.
Computers &... | Answered 2 hours ago
This Error with migration of data occurs when the connectivity is not proper with the Tally ERP ODBC. It includes the IP:Port.
The Default port for Tally ERP is 9090.
To change the port go to the installed tally ERP 9 folder. Click on Tally file type Configuration Settings, open it with a text Editor i.e. Notepad. Somewhere at the bottom will be ServerPort. Change the ServerPort to 9090. The migration will work. I have tested. Works fine with me.
Computers &... | Answered 3 hours ago
go into settings and then look for firmware and if it has upgrade firmware then you might be able too!!!!
Computers &... | Answered 7 hours ago
do you have rooted you android? if so you have apps for that and they work (i tested myself on mmotorola atrix) if you dont have root i cant help
INSTRUCTIONS FOR INSTALLING SSL ON DIRECTADMIN BKHOST VN
I. Create CSR on DirectAdmin
1. Login to DirectAdmin and click on the "SSL Certificates" option as shown in the picture
B2: Check the boxes 1 and 2 as shown below. Section 3 fills in your email. Key Size (bits), Certificate Type select as shown below. Then drag the mouse down and click "save".
Note: SSL is currently enabled for this domain.
B3: Activate SSL on Hosting DirectAdmin
Part Your Account => Domain Setup => click on the domain you need to install SSL. Most importantly, you must check the 2 boxes as shown below.
Secure SSL and Use a symbolic link from private_html to public_html - allows for same data in http and https
B4: After installing SSL successfully, you can go to the online check ssl page to check again as follows:
https://blog.bkhost.vn
The next step Really Simple SSL
We were able to use the https protocol for the website after completing this step. If you are already using wordpress website, you need to install Really Simple SSL to complete installing SSL certificate for your website.
It is done!
Computers &... | Answered 8 hours ago
There are several brands that make that model. What one do you have?
Computers &... | Answered 13 hours ago
it may also be called on-line currency, cyber currency, or the actual name of the currency for that particular game
Computers &... | Answered 14 hours ago
Install codec to your PC. You can download the codec here.
Computers &... | Answered 16 hours ago
Not being someone especially savvy in coding, I can only help so much, but I would say that a fake payment gateway would probably be more work than you're actually looking to do. If you just want a cart or payment button of some kind, embedding an image as a placeholder might be able to give you the look you want without involving the time-consuming process of creating the code yourself. Alternately, I would look into using some kind of free or very cheap program or service to use on your website. It depends on what kind of functionality you do and don't want, but I'd look into some of the payment gateway integrations in Magento, like PayUMoney.com, that doesn't demand an account be made at the checkout. That might be a good solution that gives you some of the functionality that you need for your project, but without the commitment that other services might demand.
Computers &... | Answered 17 hours ago
NOT REALLY
Computers & Internet Logo
8 questions posted
Top Jump Start Computers & Internet Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Jump Start Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Jump Start Computers & Internet
Most Popular Question
installing jumpstart advanced 1stgrade
  • Computers & Internet
