20 Most Recent Logitech Ultrathin Keyboard Cover Questions & Answers
try to turn on BT on iPad while Logitech is blinking (which means it in pairing mode and can be discovered). If that doesn't help I'd suggest to remove batteries from Logitech for 3-5 minutes then put them back.
Logitech... | Answered on Nov 08, 2015
Go to http://www.google.com/ and type in the model number of your webcam and search for its drivers and then download them.
Good Luck!
Logitech Tablets... | Answered on Sep 28, 2010
*On your Android phone or tablet, open the Chrome app .
*To the right of the address bar, tap More. Settings.
*Tap Site settings. Pop-ups and redirects.
*Turn Pop-ups and redirects on or off.
Tablets &... | Answered 2 hours ago
I know it sounds oversimplified, but this could just be a weak battery. Try switching off the tablet and plugging it into the charger for at least 12 hours before trying to restart it. Holding the power button down for 10-15 seconds when you do restart it could also help.
Tablets &... | Answered 10 hours ago
hi there.
this is all i could find out from the internet so not sure if it will work for you.
I think it,s time for a factory reset , you will lost all you data !!!!!
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
or try this link out.
android man on his back with red triangle on his chest Google Search
Revert back to factory by hard reset!
Tablets &... | Answered 14 hours ago
Hard factory reset!
Tablets &... | Answered 17 hours ago
If you did a hard reset to factory then that would return the tablet to as new when there was no password!
Something does not make sense!
Tablets &... | Answered Yesterday
Logitech Ultrathin Keyboard Cover Logo
10 questions posted
Top Logitech Tablets & eReaders Experts
Marvin
Marvin
Tom Chichester
Are you a Logitech Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Tablets & eReaders
Most Popular Question
cannot establish blue tooth connection
  • Tablets & eReaders
