20 Most Recent
Silverstone SST-ST60F (SSTST60F) 600-Watt Power Supply Questions & Answers
AFTER POWER OUTAGE IT IS DEAD
Voltage spike likely blew across the dielectric of several electrolytic capacitors. The internal fuse may or may not have survived. If it did not- replace it once and see if it is as simple as that, although you are likely looking something more.If you want to try to salvage it, recap all electrolytics and tantalums. with new high ripple current types for the electrolytics.
We had a power outage - the computer was on a
Hmmm, First of all check the fuses if any that may have burned out due to the power outage. If this doesnt help. Open up the power supply and smell it for any burned out parts. If you can smell the scent of burned electrical parts then you should replace the power supply. It should solve your problem. Also check the motherboard for any anomalies.
Hi, I've bought Silverstone SST-ST60F about 2
That sounds like you may have dislodged something inside the PSU which is now shorting out some contatcs. Be very carefull as you are dealing with mains electricity here. You could take t to a qualified Electricion to take a alook, but it is probably damaged now. I would replace it before doing any damage to Motherboard etc. -Not an expensive part.
Power supply not staying on
Sounds like when cleaning your computer, you have also cleaned your processors heat sink and fan. right.
if you have done this then there in lies problem.
either your heat sink is not placed correctly
or you forgot to apply a new thermal interface material. because once you remove the heat sink the interface material is of no use. you must apply a new one. and check that you have placed the heat sink correctly and firmly.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
