20 Most Recent Canon CanoScan LiDe110 Questions & Answers
hi my printer this problem.
release the lock switch detach the usb cable and reconnect. scanner driver will be closed code: 2,179,10
Canon CanoScan... | Answered on Feb 10, 2020
Unfortunately, that's normal for this particular model. If you read the manual, or in this case the Quickstart Guide, you'll note that the top left corner is meant to go into the arrow corner. I'm annoyed with it too. You can always do it in Post-processing by doing two "turn image 90 degrees". If there would be a setting, it would be in the scanning program as the driver for this scanner has no settings available; you would have to check to see if there's a 'reverse image' setting in the program, though I doubt it.
Canon CanoScan... | Answered on May 08, 2019
you have to run wire from you main router to the switch and put it in the in port. then you can plug in your computers from there. now if you have anew er one and it is wire less you still will hav to run a wire to the router. unless you get a repeter then all you have to do is log onto your routher and then use it like your main router
Canon CanoScan... | Answered on Sep 13, 2018
just check is copy from scanner or not
skype id [email protected]
Canon CanoScan... | Answered on Sep 13, 2016
try to uninstall the driver then install it again
note:
1-after you uninstall make restart for computer.
2-don`t connect the scanner USB until the driver installer required this.
Canon CanoScan... | Answered on Mar 19, 2016
Hi ,
Disconnect your unit from your pc ( usb and power)
Insert your install cd and run the program
Restart your pc
When Windows has settled , connect scanner back to pc .
It should run normaly .
Best regards.
Canon CanoScan... | Answered on Oct 23, 2015
Disconnect the USB (which is the power source) and install the driver. Then reconnect the USB. The driver should be detected automatically. Go into "Device Manager" to check.
Canon CanoScan... | Answered on Jan 02, 2015
Canon CanoScan LiDe110 Logo
Popular Tags
37 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
View Most Popular
CanoScan Canon
  • CanoScan Canon
Most Popular Question
unlock switch error code 2 179 16
  • Office Equipment & Supplies
