20 Most Recent RIM BlackBerry 7100G Smartphone Questions & Answers
check for interference from household appliances
check the material used in the house cladding as it may be blocking the signal
indicates an environment problem in the house as different phone makes are in use and the only common factor is the service provider
you may have to pay to get a technician in to the house to measure the signal strength from the cell tower inside your house
if you have any electronic vermin plug in units in the house try switching them off as they work at a frequency that may be affecting the performance inside the house
RIM BlackBerry... | Answered on Jul 18, 2017
Sometimes it helps to upgrade your OS ...from say (a)4.2.0.442 to say (b)5.0.0.1015. I was getting tons of uncaught applications on my 9550.I upgraded from (a) to (b) and the problem is gone.Along with battery issues.Can you try that?Your carrier must have OS upgrades for your device on their website.Good luck!
RIM BlackBerry... | Answered on Aug 17, 2013
Hi your problem is solved
Error definition:
JVM 523:System process died
A critical Java process has terminated, and the device cannot continue to operate in a normal manner
Here is the resolution for your problem
Reload the BlackBerry Device Software on the BlackBerry device
Procedure
To use BlackBerry Application Loader to load BlackBerry Device Software, complete the following steps:
1.Install the BlackBerry Device Software on your computer.
2.Open BlackBerry Desktop Manager.
3.Connect the BlackBerry device to the computer.
4.If prompted, type your BlackBerry device password and click OK.
5.Complete one of the following steps:
If the Application Updates Available window appears, click Update Now. The Application Loader Wizard appears.
If the Application Updates Available window does not appear, double-click the Application Loader icon. The Application Loader Wizard appears.
6.Click Next.
7.If prompted, type your BlackBerry device password and click Next. Note: When the Application Loader Wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation. The selected check boxes indicate applications that are already installed on the BlackBerry device.
8.Select the check box for the BlackBerry Device Software.
9.Click Next.
10.If the On the Device Backup screen appears, choose whether to automatically back up the BlackBerry device and click Next.
11.Click Finish to begin loading the BlackBerry Device Software.
12.Click Close when the software is finished loading.
Good Luck and do let me know
RIM BlackBerry... | Answered on Aug 15, 2013
Hi
u can get blackberry 7100 mep code from third party Http://blackberryimeiunlockcode.com
thanks
RIM BlackBerry... | Answered on May 20, 2012
Hello.
You can unlock your Blackberry just enter unlock code through keypad and use your Blackberry with all GSM carrier provider around the world.Blackberry 7100g Unlock code provider.
RIM BlackBerry... | Answered on Oct 13, 2011
First start off with the battery out of the phone and the usb cable unplugged. Next open the Desktop Manager, then go into Application Loader. When you get to the part where it asks for the connection type just plug in the usb cable (still leaving the battery out). If the connection changes to usb or usb, hit Next. Keep going through the wizard till you're on the last step, before you hit Install. Now put the battery in and see if the loading operation completes.
or follow this link for a complete guide of updating your phone firmware
FOLLOW ME
Good luck...
RIM BlackBerry... | Answered on Aug 16, 2011
You can get the reset option check in user manual and fix the Problem...
RIM BlackBerry... | Answered on Aug 14, 2011
Please explain more
RIM BlackBerry... | Answered on May 14, 2011
It is very easy to unlock Blackberry cell phone.You can unlock
your Blackberry by follow simple instruction.Contact your carrier
provider for free unlock code.otherwise no one give you free.you
can get MEP code for your Blackberry at cheapest rate by MEP
unlock code provider .after unlocking you will be able to use any
GSM Sim.
RIM BlackBerry... | Answered on Apr 20, 2011
Hello
You can get unlock code for your Blackberry online at cheapest rate, legal and 100% guaranteed unlock code by Blackberry unlock code provider. i hope this will help you.
Their IMEI unlock codes are 100% accurate and backed by Their money back guarantee.
RIM BlackBerry... | Answered on Apr 19, 2011
I got it once on my BB8900, it was bad i had to send it back to the dealer to reinstall a new software.
hope you have better luck than me.
RIM BlackBerry... | Answered on Jan 23, 2011
my phone has a error 523 8520 how can i fix with out the cd
RIM BlackBerry... | Answered on Aug 28, 2010
Yes you can use after unlock
How many tries you left ? only 10 tries for unlocking. wrong code can lost your tries.
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set. & ACCEPT PAYPAL
***SPECIAL CHEAPEST PRICE till 31th July from one of oldest provider.***
After unlocking from this provider's code your blackberry not only work with any network, you can use your Blackberry in any part of world with any GSM networks including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry & remove restrictions like T-Mobile or any
This site will help you a lot & good email & 24/7 phone support. http://blackberryimeiunlockcodes.com/
RIM BlackBerry... | Answered on Jul 26, 2010
To unlock your phone you will need to enter the code. This code is just a calculation of IMEI number of your phone. To find your phones IMEI number -type *#06# into your phone or look under the phone battery.
There are different online services that will calculate the unlock code for your IMEI number.
I can recommend this one (cheap and reliable).
www.unlocking.com
Note: don't share your IMEI number on free forums like this.
RIM BlackBerry... | Answered on Jul 10, 2010
Download JL Commander for free and reload OS with Blackberry Desktop manager.
RIM BlackBerry... | Answered on Jul 02, 2010
go on to your settings reset your phone you can reset it it'll just turn off your phone give it a little refresh and turn back on or you can master refresh which will turn off your phone give it a really good refresh it'll turn back on but if you master reset it will delete all our games music and stuff but im not sure about inbox emails & contacts but its up to you but if i was you i would choose master reset especially if it a new phone... so goodluck:) and please rate this solution thanks cya...
RIM BlackBerry... | Answered on Jun 06, 2010
RIM BlackBerry 7100G Smartphone Logo
85 questions posted
Top RIM Computers & Internet Experts
Artur Heise
Vincent G
Vincent G
Muntejaya Ginting
Muntejaya Ginting
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
BlackBerry RIM
  • BlackBerry RIM
Most Popular Question
mep code blackberry 7100
  • Computers & Internet
