20 Most Recent Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Questions & Answers
3answers
Soap
It is recommended that you use Hoover soap. You can use other soap that states it okay with hoovers.
9/15/2021 10:06:42 AM • Hoover F6212-900... • Answered on Sep 15, 2021
Dusty smoking smell, stops working, trips out power in house.
you forgot to say if it is a 3 phase machine if it is 3 phase then a phase in the unit is overheating and that will stop the machine then blow the breaker as all phases have to draw equal current if it is a single phase then the start/ run capacitor or centrifugal start run points are not breaking at speed and so the start windings are overheating and causing the breaker to trip Take it to an electrical motor rewind shop and have it properly tested with test equipment
10/21/2017 7:23:10 AM • Hoover F6212-900... • Answered on Oct 21, 2017
How to repair the lower intake flexible hose on the Hoover Agility
hoses are screwed into the end bits by turning in the do up direction original equipment hoses are normally glued into the end piece but with a bit of determination and a flat bladed screw driver, the glue can be broken and the end removed fit the good section of the hose into the end and screw it in using an un do direction if it is the plastic fitting itself that is broken then weld the broken section back together Basically use a soldering iron and heat the sections until the plastic melts back together There are u tube pages that show how easy it is to do as they heat weld all sorts of plastic and tips on how to improve the strength of the repair. go google and type in how to weld plastic.
4/14/2015 4:07:39 AM • Hoover F6212-900... • Answered on Apr 14, 2015
IT TURNED ON FOR TWO SECONDS THEN SHUT OFF WONT COME BACK ON?
Check for a circuit breaker on the machine.
12/17/2014 4:20:50 PM • Hoover F6212-900... • Answered on Dec 17, 2014
Hoover agility steam vac F6210 solution tank repair
Hello! The valve assembly is not replaceable on the F6210. We recommend replacing the solution tank part number 90001091, can be purchased online or through a local service center. Hope this was helpful!
11/12/2014 6:18:35 PM • Hoover F6212-900... • Answered on Nov 12, 2014
Why is the recovery tank on Hoover f6212-900 not filling up?
Hello! There are a few things that can cause the cleaner to lose suction. Please try these quick steps. 1. Remove the dirty water tank. 2. Clear the filter screen of any dirt or debris. 3. Turn the cleaner on, check your motor suction by the filter screen. 4.. Replace the dirty water tank making sure it is flush to the cleaner on all sides. 5. Lift up on top of nozzle and slide off cleaner. 6. Wipe debris off nozzle and front of cleaner with a damp cloth. 7. Replace dirty water tank. If you felt suction by the filter screen your suction should now be restored. Hope this was helpful!
11/11/2014 2:18:07 PM • Hoover F6212-900... • Answered on Nov 11, 2014
How do I fix: water continuously comes out upholstery attachment?
It's dirty so it won't close all the way. Clean it.
7/19/2014 2:47:14 AM • Hoover F6212-900... • Answered on Jul 19, 2014
5answers
Hoover Steam Vac Dual V brushes won't turn
The brushes are driven with air pressure from vacuum motor. The switch merely opens a small door to allow air flow. usually there is a screen that is plugged that stops air flow which stops the brushes from turning. I too only used the appliance once and it broke. The round disc (turbine) had become jammed with no major obstruction. Cleaned anyway and put back together and it started to work again. I am so done with Hoover--no more of their products for me. To fix. the whole brush motor had to be removed and disassembled and cleaned. Not impressed at all!
5/29/2014 8:21:36 PM • Hoover F6212-900... • Answered on May 29, 2014
0answers
0answers
Where is schematics online to replace lower hose assembly part
There is no schematic that I am aware of. I can tell you that from experience that this repair is very difficult. Basicaly the upper and lower handle unscrew along with the tank base, the hood comes off. the lower handle will split but not comes completely apart to remove the hose section. When reassembling, be sure to put the back hose gasket in the correct position. Look at it (take a picture) prior to repair first. I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
12/3/2013 10:00:20 AM • Hoover F6212-900... • Answered on Dec 03, 2013
Steam Vac Is Not Dispensing Soap
Try using a rubber tipped air nozzle and compressed air at the end of the soap dispenser line. Brief intermittent blasts of air should take care of it.
11/16/2013 6:00:11 PM • Hoover F6212-900... • Answered on Nov 16, 2013
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
122 questions posted
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Mike
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Hoover Vacuums
  • Hoover Vacuums
Most Popular Question
need schematic diagram hoover agility
  • Vacuums
