20 Most Recent
Uniden 100-channel Scanner With Am/fm Radio And Alarm Clock - 25mhz-512mhz Questions & Answers
I have a handheld uniden bearcat BC60XL T-1.
fire that trunking scanner up,the uniden is damaged,there should be no difference in signals since june 14,they are all still there,just get a new copy of the codes from radio shack,or use an online scanner,http://www.broadcastify.com/listen/?rl=rr
Touchpad doesnt register press half the time. sc200 uniden scanner
You can take it apart and see if the touch pad is a membrane with impregnated carbon pads on the back of a silicon sheet. If it is, you can use alcohol to clean the pads and board. When you take it apart, take pictures as you go and draw a diagram for screw locations and put the screws in the diagram so that they are not left out or wrong size. Good luck
