20 Most Recent
Tandberg Data 220LTO LTO 1 Tape Drive Questions & Answers
Remove stuck tape
It depends on the type of TD you are using. For many TDs, there is a manual eject screw, either on the bottom or side of the drive. You can usually access this screw without removing the cover or faceplate (although side mounting rails may need to come off). The manual ejection screw is usually recessed a little bit, and may even be covered by a piece of clear plastic (in the case of DDS 4-5 drives). It will also have an arrow indicating which way to turn to load or unload. There are usually standards within each seperate TD technology - but there is no standard across all tape drives - and Tandberg as a company is notorious for not having one at all. DDS 4 and 5 for instance - the screw is on the right side of the drive, near the rear, turning the screw clockwise will unload the media.
For a Tandberg LTO2 drive, there is no way to remove the media without removing the top cover and essentially rendering the drive unusable. If your drive or server is under warranty with onsite support - that would be the best option for a Tandberg LTO2 drive
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
