20 Most Recent Universal Remote Control Activity Based Universal Learning Remote Control Questions & Answers
2answers
Samsung program codes for ht-q100 Remote
You can try any of these 006, 011, 014, 015, 019, 027, 036, 037, 077
Hope this helps..
7/4/2008 3:26:46 PM • Universal Remote... • Answered on Jul 04, 2008
Program code
onkyo rc 518m find
1/6/2008 2:39:33 AM • Universal Remote... • Answered on Jan 06, 2008
2answers
What is the code for ikon tv
028,022,027. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device. Search the site by type in the "brand name" to your device; that you want set-up code, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
3/25/2024 8:09:04 PM • Universal Remote... • Answered on Mar 25, 2024
How do I get my aluminium universal remote control to do automatic search
Not many do automatic scan and program. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote Google make model manual ..
2/28/2024 5:38:14 PM • Universal Remote... • Answered on Feb 28, 2024
I have RCA 4288 LED TV. How do I set universal remote control Chunghop 309sp to work on it?
Question edited for clarity and 'ECA' to 'RCA'. Better to buy a Remote made for that television. No programming and same buttons as the old one. https://www.google.com/search?q=RCA++4288+LED+TV+replacement+remote Have a read https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote Here are the codes if you wish to proceed with the Chinese Chunhop
  • RCA TV 1000 , 1003 , 1004 , 1005 , 1006 , 1007 , 1019 , 1054 , 1055 , 1082 , 1096 , 1098 , 1099 , 1100 , 1101 , 1102 , 1103 , 1129 , 1179 ,1181 , 1188 , 1190 , 1196 , 1202 , 1203 , 1212 , 1215 , 1233 , 1257 , 1258 ,1266 , 1278 , 1279 , 1281 , 1286 , 1352
8/11/2023 11:06:12 PM • Universal Remote... • Answered on Aug 11, 2023
2answers
How to set up my philmore PM-RC18 UNIVERSAL REMOTE CONTROL
Setting up the Philmore PM-RC18 Universal Remote Control requires programming it with the appropriate codes for your devices. Here are the general steps for setting up the remote:
  1. Gather the necessary information: Before you start, you will need the brand and model numbers of the devices you want to control with the remote, such as your TV, DVD player, or audio system. Make sure you have this information handy as you will need it during the programming process.
  2. Power on the device: Turn on the device you want to control with the remote, whether it's your TV, DVD player, or audio system.
  3. Find the code list: The Philmore PM-RC18 remote control comes with a code list that contains the codes for various brands and models of devices. Look for the code list that came with your remote. It may be included in the user manual or available online on the manufacturer's website.
  4. Enter programming mode: Press and hold the "SET" button on the remote until the LED light on the remote turns on and remains lit. This indicates that the remote is now in programming mode.
  5. Enter the device code: Enter the appropriate device code for your device using the number buttons on the remote. The LED light on the remote should blink once to indicate that the code has been successfully entered.
  6. Test the remote: Point the remote at the device and press the "POWER" button. If the device turns off, it means the remote has successfully programmed with the correct code. If not, repeat the above steps with a different code from the list until you find the correct one.
  7. Store the code: Once you have successfully programmed the remote, press the "SET" button again to save the code. The LED light on the remote should turn off, indicating that the code has been stored.
  8. Test other functions: After programming the "POWER" button, try using other buttons on the remote, such as volume or channel buttons, to ensure that all the desired functions are working correctly.
  9. Repeat for other devices: If you want to control other devices, such as a DVD player or audio system, repeat the above steps with the appropriate device codes.
  10. Exit programming mode: Once you have finished programming all your devices, press the "SET" button one more time to exit programming mode. The LED light on the remote should turn off.
Note: If you are unable to find the correct code for your device in the code list, the Philmore PM-RC18 remote also has a "code search" function that allows you to search for the correct code manually. Refer to the user manual or online resources for instructions on how to use the code search function. If you encounter any issues or difficulties during the setup process, refer to the user manual or contact Philmore customer support for further assistance.
4/10/2023 8:25:41 PM • Universal Remote... • Answered on Apr 10, 2023
I need the tv code for a bush BMKDVD40 for a universal remote control
The TV code for the Bush BMKDVD40 for a universal remote control is 0376. You can usually find the code listed in the manual for your universal remote, or you can search for the code online by typing in the model number of your TV.
2/4/2023 5:32:22 AM • Universal Remote... • Answered on Feb 04, 2023
I need codes and instructions for a RCU600WMS 1504P remote ?
The user manual for the RCA RCU600WMS is available here: https://www.rcaaudiovideo.com/remote-code-finder/?sku=RCU600WMS&productType=TV . The manual includes some codes. For others, you need the revision number which is inside the battery compartment of the remote. Note: the RCU600WMS manual is from 2001. Thus the included codes in the manual will be for devices manufactured before 2001 (~6 months before the remote was programmed). 1504 was not a value in the available list of revision numbers on the RCA code site. Most of the revision codes were 5 digit numbers. I hope this helps. Cindy Wells
1/27/2023 10:53:08 PM • Universal Remote... • Answered on Jan 27, 2023
Need a iDigital universal remote code
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
12/15/2022 10:43:29 PM • Universal Remote... • Answered on Dec 15, 2022
Senzu Television has no remote only a universal remote control.
Question edited to what I think you thought you were saying. Movies World is probably a subscription channel and you are hearing audio only, and have to pay to see the picture. They call it 'Preview Mode' and you often see 5 minutes or less of audio and video at the beginning of the film. If you can hear it, the remote is working. If other channels have sound AND picture, the television and remote are BOTH working. Senzu seems to be an Australian or NZ set, where as we are in North America. It is always better to buy a copy remote made for the set. https://www.google.com/search?q=senzu+ld2400+remote+replacement Senzu Remote Codes
Remote Control Codes For Senzu TVs
https://www.directutor.com > content > remote-control-... Remote Control Codes For Senzu TVs. Senzu TV Remote Codes (3 Digit Codes): 201 205 000 297 257. Senzu TV Remote Codes (5 Digit Codes): 12493. codes ...
Senzu TV Universal Remote Codes & Program Instructions
https://universalremote.codes > senzu-tv Jun 30, 2021 - Senzu TV Universal Remote 3 Digit Codes · 205 · 257 · 000 · 201 · 297 ...
https://codesforuniversalremotes.com > remote-control-... Below is a list of all Senzu remote control codes to be used with ALL Senzu televisions. These codes can be used with all universal remotes if your remote needs ...
11/23/2022 12:27:25 AM • Universal Remote... • Answered on Nov 23, 2022
2answers
Cual es el codigo de chunghop rm-68e para una tv LG
En Mi Caso Para La MARCA TV LG Los Codigos pueden ser 024 - 040 - 098 -043 - 140 - 259 - 260 y 261. Espero que los pruebes ^^ Lo saque del manual, Donde el vino de control remoto universal. Marca: Chunghop Rm-68e Remoto Universal Tv
10/8/2022 9:44:57 PM • Universal Remote... • Answered on Oct 08, 2022
Televison & Video Logo
Popular Tags
11 questions posted
Top Universal Remote Control Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Universal Remote Control Televison & Video
Most Popular Question
program code
  • Televison & Video
