20 Most Recent Keurig 5048 My K-Cup Reuseable Coffee Filter Questions & Answers
16 oz setting dispenses 32 oz of coffee
Yes this is a problem and it was fixed in 2014.
2/7/2014 9:05:55 PM • Keurig 5048 My... • Answered on Feb 07, 2014
Coffee is weak, muggy & all in the bottom of the cup
Call 1-866-901-2739 for factory assistance Now,
2/7/2014 7:48:57 PM • Keurig 5048 My... • Answered on Feb 07, 2014
Why does my Keurig k-cup leak from the bottom.
Needs cleaning or seals get damaged.
1/31/2014 11:11:54 PM • Keurig 5048 My... • Answered on Jan 31, 2014
Can not get the make to close over the my-k cup
You have to remove the cup holder in the Keurig first. Just grab it and twist to loosen .
1/8/2014 7:48:32 PM • Keurig 5048 My... • Answered on Jan 08, 2014
3answers
My kcup brewer leaks water
I had the same problem I bought a 1/2" rubber washer and duct taped it to the top of the reusable unit and it has been working great for about a month, the indent in the reusable filter is too far away from the brew section of the machine
10/14/2013 8:42:28 PM • Keurig 5048 My... • Answered on Oct 14, 2013
Leaking water when using my k cup
Long story short, it will leak from under the screw cap (rarely) and from the rubber ring around the puncture pin. The grounds clog the metal filter and creates pressure that escapes from under that rubber ring. I cut a thin styrofoam plate to fit under the screw cap. It's really snug for the first few times, then it will loosen up. Second is to tighten the seal between the top of the 'my cup' and that rubber seal. I used 2 styrofoam rings that sit between the 'my cup' and the hard plastic it sits on when you fit it in the hole. It bring the cup like 1/8 inch higher to the pin and increases that seal. I made many cups after that and it has never leaked. I'm looking for a good rubber ring to fit around the 'my cup' to replace the rings for the seat.
3/21/2012 7:07:03 AM • Keurig 5048 My... • Answered on Mar 21, 2012
2answers
It's actually my Mom's Keurig
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
1/21/2012 8:34:44 PM • Keurig 5048 My... • Answered on Jan 21, 2012
I have solved the problem
That will work for the adapter but will puncture regular kcups. I put a 1/4 inch spring behind the gasket(delta faucet part) I had to cut it down a bit. This will make it work for both the adapter and kcups.
10/4/2011 3:59:09 PM • Keurig 5048 My... • Answered on Oct 04, 2011
The coffee grounds are dry after the cup is
There's a needle that punches a hole on the bottom of the K-cup. That needle is clogged. Poke it with a paper clip or a thin wire to unclog it.
8/24/2011 5:09:52 AM • Keurig 5048 My... • Answered on Aug 24, 2011
2answers
K-Cups disappointing
I had same problem and called Keurig. They advised me that the gasket in the upper portion, where the top needle is needs to be brought down about half way, almost even with the bottom of the top needle. Be careful not to poke yourself. I brewed a cup with the resuable filter assembly and it worked great. It should stay in that position until you use an actual k-cup. When using it will push the gasket back up, as it needs pressure to puncture the hole. To go back to the resuable filter, you will need to lower the gasket again. She advised me that they are working on a fix for this issue and will notify you of any replacement parts, as long as they have your current contact info.
3/11/2011 8:43:11 PM • Keurig 5048 My... • Answered on Mar 11, 2011
When using MY K-Cup reuseable
I googled this problem for 3 days. I was reluctant to try anything that would screw up my machine, as I have been very happy with it, except for the re-usable filter performance.
I wiggled the o-ring washer around top sharp thingie by maybe 1/8 inch and that fixed it. K-cups are running normal as well.
2/24/2011 1:03:12 AM • Keurig 5048 My... • Answered on Feb 24, 2011
When using the reusable filter the coffee spews
2/15/2011 4:26:28 AM • Keurig 5048 My... • Answered on Feb 15, 2011
Will "My K-cup fir B140 and B145? Thank you.
Nope.
1/3/2011 10:42:05 PM • Keurig 5048 My... • Answered on Jan 03, 2011
How do I make my own coffee in the Keurig? I have
Sorry to read about your problem, I hope this helps you out.
No problem, you will goto the maker, and open the latch, as if you are going to put in a k-cup..
Well that little brown holder, comes out..use 2 fingers and try to snap it out...when you get it out. put in the reusable filter..and you are done
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
12/25/2010 10:00:48 PM • Keurig 5048 My... • Answered on Dec 25, 2010
DOSE THE KUERIG COFFE MAKER B 60 HAVE WATER BUILD
nope just the holding tank
12/18/2010 8:52:11 PM • Keurig 5048 My... • Answered on Dec 18, 2010
0answers
0answers
Coffee Makers & Espresso Machines Logo
35 questions posted
Top Keurig Coffee Makers & Espresso Machines Experts
Pierre Laplante
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Keurig Coffee Makers & Espresso...
  • Keurig Coffee Makers & Espresso...
Most Popular Question
when using reusable filter coffee spews
  • Coffee Makers & Espresso Machines
