20 Most Recent Spidem Trevi Anthracite Espresso Machine Questions & Answers
I had the same problem with Spidem My Coffee with no instructions how to turn the light off. used the Saeco instruction and solved.
simply press the steam button for 6 seconds and the light will turn off
Spidem Trevi... | Answered on Mar 18, 2010
Try adjusting the grind a little coarser, then remove the brew unit and clean the shower screen.
Spidem Trevi... | Answered on Sep 29, 2009
check reset buton on tank,or maybe element dont work or computer board
Spidem Trevi... | Answered on Aug 01, 2009
Remove the brew group and clean the shower screen at the top. This might be blocked.
Spidem Trevi... | Answered on Jul 15, 2009
Have you a rapid steam boiler in the machine? check the termal fuse on it, can be the rapid steam boiler that is broken to.
Spidem Trevi... | Answered on Jul 11, 2008
Take out the brewing unit and check the hole in the chassi (where the brewing unit was), make sure that hole is clean.
If the hole is clean and the remain leaking then your boiler is gone and have to be replaced:-(
You may have a legitimate mechanical malfunciton but sometimes the simple solution is the right one! The chute on this (and other) superautomatic does not like the oily residue that beans inevitably leave. All it takes it gently putting one or two fingers into the bean hopper as the grinder motor starts to sound louder/faster (this is caused by the grinder motor being under less load/strain because no beans are feeding) and wiggling for 1-2 seconds. If you do this immediately after hearing the grinder motor's rpms increase you will not get a "fill bean hopper" error message2.gif. No hard pushing is required, just a gentle wiggle. There is a shroud over the actual bottom of the hopper, so you don't want to stick your fingers beyond that. If you are concerned about actually sticking your fingers into the hopper while the grinder is running, you can simply push down on the top of the beans with gentle pressure which will in effect force the beans down and accomplish the same thing. This technique + regular cleaning of the grinder may be all you need. Hope this helps! Tony
Spidem Trevi... | Answered on Jan 04, 2008
http://www.fixya.com/tags/machine_reset_button/coffee_and_espresso_makers/spidem
Spidem Coffee... | Answered on Mar 05, 2019
TIS A SHAME THEY HAVE MADE SUCH SMART MACHINES THAT WE CAN NO LONGER DRINK JUST PLAIN COFFEE USING PRE-GROUND BEANS
Spidem Coffee... | Answered on Feb 12, 2019
not adding enough. water to make a BIG cup
Spidem Coffee... | Answered on Nov 28, 2016
When the grinder spins free and fast it only means that fresh beans are not feeding into the burrs. This happens when:
1- Grind setting is too fine and beans cannot enter the grinder mechanism.
2- Use of oily dark roast beans can clog the ground coffee chamber and preven the fresh beans entering the grinder.
3- The ground coffee chamber outlet is clogged due to oily beans or too fine coffee setting.
When you cleaned the grinder you may not have cleaned the coffee outlet to the doser on the left. You can clean the outlet to open the passage of coffee grounds to collect in the dosing device..
After cleaning the outlet, you should next make sure that coffee grounds are not packed in the doser. The doser is inside the door right above the brew group.
To access the doser:
1- Remove water tank.
2- Remove the brew group.
3- Lay the machine on its back for full view of the doser.
4- Pull the doser door open (it is like an Attic door.
5- Keep the doser door open and clean the inside with a brush. The outlet from the grinder is on the right side with a wire wiper cleaner that moves across the grinder outlet fills from the grinder. This opening.
Use a brush to clean the doser.
On the left of the doser space there is a plastic flap that is pushed to the left when coffee grounds fill the doser.
At certain distance push back (1/4") the notch on top of the flap pushes the doser micro switch pin to stop the grinder. Push the flap gently to the left to make sure that it is moving well. With each push back of the flap, one can hear the feeble click sound from the micro switch.
When the above cleaning is done, try the grinding.
If the conical burrs have not been replaced for over 2500 grinds, it is time to do so.
The above grinder and grinder doser cleaning instructions are available as download files on the following page link:
One can find many useful maintenance guides on one page.
Good luck.
http://www.partsguru.com/MaintenanceofEspressomachines.htm
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Spidem Coffee... | Answered on Feb 11, 2015
Spidem Trevi Anthracite Espresso Machine Logo
Popular Tags
13 questions posted
Top Spidem Coffee Makers & Espresso Machines Experts
Pierre Laplante
graybeard32301
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Spidem Coffee Makers & Espresso...
  • Spidem Coffee Makers & Espresso...
Most Popular Question
decalcification light stays constantly
  • Coffee Makers & Espresso Machines
