20 Most Recent HP Photosmart 6510 e-All-in-One Printer Questions & Answers
https://www.youtube.com/watch?v=Ji-tkg9SNh8&list=PLEOoK1xQrNoEWPZjpV-z7mSqJSxXlfRh4&index=2&t=0s
https://www.youtube.com/watch?v=KLGgRr2NhcE&list=PLEOoK1xQrNoEWPZjpV-z7mSqJSxXlfRh4&index=3&t=0s
HP Office... | Answered 12 hours ago
Solution 1:
  • Press and hold the "*" key.
  • Press the "#" key and release both keys, display should say "Enter Special Key Combo"
  • Press and release in sequence the "1", "2" and "3" buttons: display should say something like "support" R0631M
  • Press and release the right arrow button until the display says "System Configuration Menu".
  • Press and release the "OK" button: display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status"
  • Press and release the "OK" button.
    Display should say "Hardware failure status: Clear. Press OK to clear".
  • Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
  • Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Not print at this stage.
  • Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall.
  • Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
  • Turn the unit on. The printer may display message "Use the power button to shutdown the printer" followed by "Press OK to continue". Press OK.
  • The Printer will start the "One time ink initialization process". Allow this process to complete and do not interrupt.
  • Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Solution 2:
  • Unplug the power from behind the printer.
  • Wait for 60 seconds.
  • Hold down the "print photo" and "cancel" at the same time. You should be able to see it with a blank screen for several seconds.
  • It's done
  • Try again and again if at first it doesnt work.
Solution 3:
  • Unplug the all-in-one from power.
  • Wait 30 seconds.
  • Plug in the power only.
  • Repeat steps 2-4 two more times.
  • On the third time after plugging the unit into power check the functionality.
Solution 4:
  • Unplug the power cord from the back of the HP All-in-One.
  • Wait for the unit to go to the sleep mode. Wait for 60 seconds.
  • Press and hold Print Photos & Photo Fix buttons simultaneously on the control panel; keep them pressed and reconnect the power cord to the All-in-One.
  • Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
HP Office... | Answered 15 hours ago
There are no HP ink jet manuals available
HP Office... | Answered Yesterday
How can I Resolve HP Printer Error Code 0x80070490?
To resolve the error, remove the unknown device from the Printers list in Device Manager.
  1. Search Windows for device manager, then click Device Manager in the list of results.
  2. Click Printers.
  3. Right-click Unknown device, then select Uninstall to remove it.
  4. Click Retry in the Windows Update window to install the updates.
Resolve The issue of Hp Printer Error Code 0x83c0000a by just following a few steps.
Sometimes users do not find any reliable solution to fix your HP device errors. In this case, it is suggested that get HP Support Assistance from experts to resolve problem and avoid hectic troubleshooting methods. A team of certified experts is always available to offer quick service to customers to fix their HP device issues.
The issue of Hp Printer Error Code 0x83c0000a occurs due to the NOS loader app error.
Visit the link shown below and resolve the issue with the help of the Hp Technical support team. Or contact the team to get an Online technical assistant.
Visit the Website:-
http://www.hptechnicalsupportphonenumber.com/blog/how-to-fix-hp-printer-error-code-ox83c0000a-message/
Steps to Fix HP Printer error code oxc4eb827f Issue
  1. Step 1: Take out the ink cartridges. ...
  2. Step 2: shut down the computer system. ...
  3. Step 3: Power off the wireless router. ...
  4. Step 4: Completion stage. ...
  5. Step 5: plug-in procedure. ...
  6. Step 6: Install the cartridge. ...
  7. Step 7: Create a copy. ...
  8. Step 8: Turn on your computer system.
Steps to Fix HP Printer error code oxc4eb827f Issue Step 1: Take out the ink cartridges
When the printer is on, the user will need to remove the ink cartridges and after that unplug the power button from the back of the HP printer.
After that simply shut down the system device
Now you need to off the wireless router.
Complete the process and wait for minimum 60 seconds.
Plug in the power cable openly to the printer
Installation of the cartridges as it is a required step that is to be performed must.
Craft a clear copy of cartridge which is well recommendable for the users.
The next step is that you have to open the computer
Step 9: Power on the router
HP Office... | Answered 2 days ago
5 Easy Steps to Fix HP Printer Error Code 0x83c0000a HP Printer Error Code 0x83c0000a can be solved by modifying the printer settings and downloading and updating appropriate drivers. HP Printer Error OX83C0000A in general represents a NOS Loader App error in HP Printer. Due to this error, your printer becomes unresponsive. and therefore the code keeps on showing on screen. Issues like Printer staggering, No printing signal, Blue screen on PC, PC motion on start, Warm printer fall flat fly up, Unfit to revive current windows to latest window, Unfit to revive PC drivers are all because of "Error 0x83c0000a in HP Printer".
Steps to Fix HP Printer error code 0x83c0000a issue Step1: Check For HP Printer Affiliation
  • You need to turn on your printer
  • Disconnect all the power cords from the rear side of the printer
  • Check if the printer is control on.
  • Check for interface is joined truly or not among printer and device.
Step2: On the printer control panel check for your estimated ink levels feature. Control panel options may differ based on the model of the printer.
Step3: Download Drivers for HP Printer
Step4: HP Printer Driver Updation
  • Find and twofold tap diverse devices, find the printer name you have to revive.
  • Right click on it
  • Update HP Printer Driver Software.
Step5: Modifications in HP Printer Setup/Settings
HP Printer Error Code 0xc05d1281 is generally occurring when the Ink System Failure has failed.
Solution 1:- Unplug the printer
  1. Unplug the power from behind the printer by disconnecting all the power cable from the source.
  2. Wait at least 2-3 minutes.
  3. Then connect the power cable again.
By Caitlin Dunn HP Printer Error Code 0xc05d1281 is generally occurring when the Ink System Failure has failed. The other causes to happening this error include a Problem with Printhead, Printer Failure, and hardware failure, etc. If your HP printer had a paper jam and now is displaying Ink System Failure 0xc05d1281, you are unable to print, scan, copy, and receive faxes, then don't need to worry about it. As it's suggested by the HP tech support team, this Error Code 0xc05d1281 can be easily fixed with the simple troubleshooting steps. Here, the blog will guide you very easy steps on Fix HP Printer Error Code 0xc05d1281?, then follow the steps which given below.
Solutions to Fix HP Printer Error Code 0xc05d1281:- Solution 1:- Unplug the printer
  • Unplug the power from behind the printer by disconnecting all the power cable from the source.
  • Wait at least 2-3 minutes.
  • Then connect the power cable again.
Now, check the error is resolved; if not then, go to the next solution.
Solution 2:- Clean Head You should try to check and clean the head contact pin condition of the carriage unit.
  • Verify that it's correct cartridge for your HP printer or not.
  • Check all the Cable connection, especially the carriage FFC.
If the Error Code 0xc05d1281 continues displaying, then you should go to the next solution.
Related Blog: How to Fix HP Printer Error Code 0XB80D8128? Solution 3:- Reset Printer
  • Then wait for the unit to go to the sleep mode.
  • Press and hold Print "Photos & Photo Fix" buttons simultaneously on the control panel; keep them pressed and reconnect the power cord to the All-in-One.
  • Now, continue pressing the buttons while the display goes blank or Reset shows on the control panel display.
Solution 4: Perform Carriage Task You should try to check and your Printer carriage and perform some task by the following way.
  • Turn off the power of your HP Printer.
  • Open the panel.
  • Turn on the power.
  • Wait for print carriage to start moving to the left.
  • Let it go past halfway.
  • Before print carriage reaches to left-hand side shuts the cover.
  • Leave the Printer turned on.
Solution 5-: Perform Print Head Task
  • Unplug the power cable of the HP Printer.
  • Then open the printer.
  • Next, push the whole print head mechanic to the center
  • While the printer still open, plug the power and turn it ON.
  • Once the printhead still moving and is going to the very LEFT, close the cover.
  • Wait for some time, until its boot up.
Now try to gain start the printer and check the Error Code 0xc05d1281 is resolved.
After performing all the above steps, still, if you are getting the same error code, then you should contact HP Customer Support professionals for the comprehensive guidance &advice
HP Office... | Answered 3 days ago
  1. How to Troubleshoot HP Scanner Failure Error Code 30.1.8? by HP Support Number HP Technical Support
    Today, HP is a well-reputed brand which is manufacturing world-class products based on the latest technology. It is globally recognized supplier offering top quality products like computers, laptops, tablets, scanners, and printers. HP is also producing latest HP scanners as per user's needs and demands. HP scanners are easy to use, best in the performance, latest in the features and affordable in the prices, so they are now in the big demand among users. Just by becoming the first choice of smart users, HP scanners are the advanced devices which are mainly used for various purposes. While using them, you can face any kind of error suddenly. HP scanner failure error code 30.1.8 is one of them. This is a scanner calibration error code that occurs when the cable might not be connected rightly or your scanning machine is locked. To fix this error code, we are suggesting the right, proper and complete guidelines. And you can take the suggestion from online HP scanner tech support experts immediately.
    Step 1:- You need to raise your ADF and confirm that your scanner lock is in the unlocked position as per HP scanner team guidelines. During this process, if you get any difficulty, you should take online help from certified scanner experts. Step 2:- You need to turn on MFP and check carefully and properly if the optical assembly is working properly or not. During this process, if you face any trouble, you can call directly with scanner experts instantly.
    Step 3:- If this is not able to move, the users have to remove the scanner gals to check instantly if whatever is confining main optical assembly from moving. If you have any confusion regarding this step, you can call online technical support team immediately.
    Step 4:- To resolve this error code, confirm that this optical assembly drive belt is installed appropriately.
    Step 5:- Customers should validate that the connector on the scanner controller PCA is appropriately positioned and connector on your scanner controller PCA is consistently installed.
    Step 6:- You need to verify that the scanner connector for the scanner home position sensor is placed properly. If you are stuck into any critical situation, you should take help from technical support executives immediately.
    Step 7:- If HP scanner failure Error code 30.1.8 occurs, again and again, you must replace your scanner control board immediately.
    Above all steps are not sufficient to solve error code 30.1.8, and then you can call at HP scanner support phone number 1-888-657-9666 immediately to get right technical solutions for this error.
    View Source: https://goo.gl/QtKJgg
HP Office... | Answered on Jan 21, 2020
sadly no clue as are not hp tech support
HP Office... | Answered on Jan 20, 2020
HP Photosmart 6510 e-All-in-One Printer Logo
8 questions posted
Ekse
Thomas F. Schneider
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
hp photosmart c7280 paper jams
  • Office Equipment & Supplies
