20 Most Recent Brother FAX-2920 Plain Paper Laser Questions & Answers
Is the LCD working (can see characters) ?
Brother FAX-2920... | Answered on Jul 01, 2014
Call your fax machine from a regular phone to see if it rings / answers.
Brother FAX-2920... | Answered on Dec 01, 2013
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Brother FAX-2920... | Answered on Feb 08, 2012
This is a fault with the main pcb. The only cure is to have it replaced.
Brother FAX-2920... | Answered on Aug 26, 2011
Ok so changing the drum has not resolved the problem. I suspect you have a bad contact between the machine and the drum. Its been a while since i have worked on a 2920 but i remember a case of a drum problem which turned out to be a poor contact from one of the contacts on the left side of the machine. Also take another look inside where the drum sits and you will see two runners that are spring loaded. the drum rests on these and i have known the springs to jump out and the runners have become stuck. of course this allows the drum to sit incorrectly and that may cause the error.
If no joy then let me know where you are located.
Good luck
It may be they have been sending the fax several times using ring back, if you go into the menu there is a setting to clear memory this should stop the copies.
Brother FAX-2920... | Answered on Aug 11, 2011
I don't know if you've got the problem still now (the post is 4 months ago) but the solution is:
open the front door
press the key options
press the blue key
press 1 and 0
close the door
turn off and on
that is!
Bye
Brother FAX-2920... | Answered on Feb 18, 2011
see above
Brother FAX-2920... | Answered on Oct 06, 2010
The problem is most likely that the eject area is fouled. Other than that clean the rollers especially the last roller in the chain with Isopropynol. If that doesn't work, check that the roller is moving, if not replace it.
Your machine is a laser type fac (not inkjet). It does,t use ink, but toner. To learn how to replace the toner cartridge you should read the User's Guide.
You can download it from here: Brother FAX-2920 User's Guide
manual.
Look for section "Troubleshooting and routine
maintenance" / Replace the Toner Cartridge / How to replace the toner cartridge and Replacing the Drum Unit (pags. 112 and following of the User's Guide).
Brother FAX-2920... | Answered on Oct 03, 2010
This is a common problem on the fax-2920. It is caused by a build up of dust and dirt on the ejection roller that stops it from grabbing the paper as it is fed up towards it. To fix it you have to remove the fuser unit for access and wipe all four of the little rubber wheels over with alcohol. Put it all back together and it should be all good!
Brother FAX-2920... | Answered on Aug 31, 2010
where is it jamming?
Brother FAX-2920... | Answered on Aug 27, 2010
Brother FAX-2920 Plain Paper Laser Logo
48 questions posted
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
brother intellifax 2920 reset drum life
  • Office Equipment & Supplies
