20 Most Recent Brother BRTPT65 PT-65 Label Maker Printer Questions & Answers
Take out your label cart and pull the tape a bit. If it is hard to pull, it is jammed inside. Just keep gently pulling until it frees up. If this is the problem, it should work when you replace the tape cart. Had the same problem with mine yesterday - it now works.
Brother BRTPT65... | Answered on May 20, 2015
i've never been able to change the font. just sizes, and make it BOLD, Italic, underlined ect.
only one style font however
Brother BRTPT65... | Answered on Mar 11, 2015
I once had a problem and solved it by opening the printer, pushing on parts wherever I could. When I had closed the label printer, it miraculously worked again! By doing so I may have have removed dust or cleaned contacts, which might have gone bad or eroded, like the volume control of a guitar.
Brother BRTPT65... | Answered on Jul 15, 2014
You have turned on the "Mirror print" option.
Here is a link to the manual. Go into the print functions and look up the Mirror Print option, that will show you how to turn it off:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_65_65SB_65SCCP_65SL_65VP_EN_166.PDF
Brother BRTPT65... | Answered on May 08, 2014
Make sure the tape is running through the tape guide on the plastic cartridge. This just happened to mine and I finally figured it out.
Brother BRTPT65... | Answered on Feb 12, 2014
need to hit enter after changing it.
Brother BRTPT65... | Answered on Jan 22, 2014
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Brother BRTPT65... | Answered on Jan 03, 2014
Brother BRTPT65 PT-65 Label Maker Printer Logo
101 questions posted
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
p touch model pt 65 home hobby label
  • Office Equipment & Supplies
