20 Most Recent Nor-Lake KLB7488C Questions & Answers
Unfortunately, this model has had quite a few problems, because it is such a complicated refrigerator. Many times a shorted component that is connected to the Iceland main control board will affect completely unrelated items making it easy to chase your tail for hours. I would suspect the freezer thermostor - only because we have had to replace it many times in the past.
Suggest you go to the www.searspartsdirect.com and copy the electrical diagram and then verify electrical reading on the main PCB, to try to isolate the problem.
Nor-Lake... | Answered on Jan 26, 2012
There are a few companys that make temp chart recorders that are battery controled and you could get one of these and just put it inside the refrigerator, problem solved. Check at United Refrigeration, and Johnstone Supply they both have manufacturers that will allow you to keep charts. The 2 things to keep in mind 1 How often are you going to change charts, 2 what temperature range are you looking for.
Oh yes and Im sure there is a company that makes a remote sensed temp recorder that can tie into a computer and print out charts as needed. This is a little more specialized but I know the technology is asvailable. Probably Johnson or Penn Controls would know about this.
If this helps you in any way please rate me as high as you can. If you need to contact me and I can do the searching for you post back.
Nor-Lake... | Answered on May 29, 2009
water vapour in the bag, turns to condensate when the temperature drops, and then it freezes. You can avoid it by using a vacuum packing Food-Saver machine. No problem though, just brush the ice off and carry on.
Refrigerators | Answered 8 hours ago
cooper line works best
Refrigerators | Answered 9 hours ago
Granite. Marble is for work surfaces.
Refrigerators | Answered 22 hours ago
CALL A REPAIR SERVICE THEY ARE NOT DIYER FIXABLE
Refrigerators | Answered Yesterday
Check the thermostat settings if not it probably has a leak.
Refrigerators | Answered 3 days ago
my ice machine stops making ice a 60 minute timer pops up ...
www.techtownforum.com > Discussions
Sep 5, 2017 - my ice machine stops making ice a 60 minute timer pops up and says Hpco active. why is it doing ... HPCO is a high pressure cutout control. Why does a contactor short cause the HPCO to trip? - techtown
Feb. 12, 2018
Archives - techtown
May 1, 2020
Discussions Archive - Page 120 of 222 - techtown
Apr. 11, 2020
More results from www.techtownforum.com
Refrigerators | Answered on Aug 06, 2020
Refrigerators Logo
0 questions posted
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Nor-Lake Refrigerators
Most Popular Question
type refrigerant
  • Refrigerators
