20 Most Recent
LG VX2000 Questions & Answers
How come my LG Env3 only displays the Verizon logo?
There are a few possible reasons why your LG Env3 is only displaying the Verizon logo:
- The phone is stuck in a boot loop: This can happen if the phone's software becomes corrupt, causing the phone to continuously reboot and display the Verizon logo.
- The phone is stuck in a firmware update: If the phone was in the middle of a firmware update and the update failed, it may be stuck in a loop and only display the Verizon logo.
- The phone has a hardware issue: If the phone's hardware has become damaged or malfunctioning, it may only be able to display the Verizon logo.
- The phone is locked: If the phone is locked with a passcode or pattern and you've tried to enter it multiple times, it may display the Verizon logo.
If you're unable to fix the problem by yourself, the best solution would be to contact the manufacturer or the carrier to get the phone checked.
It is also possible that the phone was previously owned by someone else, it may be locked to a carrier and the only option is to contact the carrier and ask for assistance
May have blocked number how do i unblock
On the android system go to phone and recent and locate the number and select it by touching it for a couple of seconds you should get a menu that comes up and says block/unblock. If the number is not listed or block is the only option then it is not blocked
10/24/2016 10:29:40 AM •
LG VX Cell...
Answered
on Oct 24, 2016
Delete files from sim
on phone you should have a setup app, and it should tell you about your sims card, it should let you delete from there
