20 Most Recent
Nokia 3200 Questions & Answers
My phones displays the message Insert SIM Card even though it has the SIM Card.
Nokia 3200
Answered
on Jun 26, 2019
Hi restriction code are nothing that code which help to remove the network lock in your mobile .To get code visit
unlocking4free.com here they ask you the network name to which your Nokia 3200 mobile is locked and the imei number of your mobile .Then at last they generate code to unlock your mobile at free of cost.
Nokia 3200
Answered
on Jan 10, 2019
Dear Sir / Madam,
My hand set is NOKIA 6500s-1 , not NOKIA 3200
can you please help me as i have a NOKIA 6500s-1 handset of UK
and I want to insert another network SIM . and when I insert other SIM
it asks for Restriction code. Please help me . this is the detail of
mobile
NOKIA 6500s-1
V04.81
RM-240
(c) Nokia
Varant:01.06
IMEI: 353076027844417
Language: V 04.81
Service by United Kingdom-3
Contact me at:
[email protected]
Nokia 3200
Answered
on Jul 27, 2018
Only try the code once and once only!!!
Please remember you only get 3-5 attempts before your mobile becomes hardlocked.
If you have already tried different codes before mine your mobile could already be hardlocked.
If it is hardlocked you will get one the following messages Can Not Undo Restriction / Not Allowed
If you mobile is hardlocked the only way to unlock it is by taking/sending it to a professional unlocker.
Please make sure the information you give is correct before typing in the code.
Here is your code: #pw+248975072651776+7#
If the mobile gives no response/no message then do the following: Insert a non accepted sim, press the undo button, a box should appear saying enter restriction code, enter the code given and press ok
Remove sim first,power on the phone.
After the phone boots up, press #
Press * 3 times fast for (p)
Press * 4 times fast for (w)
Press * 2 times fast for (+)
Verify code before pressing the last #.
"Phone restrictions off", it's unlocked!
Nokia 3200
Answered
on Feb 01, 2018
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Nokia 3200
Answered
on Jul 06, 2017
you simply will need to take your phone to a t-Mobil dealer in town. Tell them you have lost your sim card and you need a replacement. They can activate a new sim card for you. How ever most places do charge you $20.00 for the new sim card.
please rate this as fixya if it has answered your question.
Nokia 3200
Answered
on Oct 28, 2016
Dear.
Ur hand free connector is short may be water inside. just open it and clean and reassemble will ok sure.
Nokia 3200
Answered
on Mar 31, 2015
remove the back of the phone take out the battery and it is under there
Nokia 3200
Answered
on Jun 08, 2014
You can remove the Network restricted error from your phone using Restriction code.You can get such codes from
TheUnlockArena.com here you need to specify your country,Network name to which it is locked,IMEI number of your phone.Then they deliver unlock code to you through mail with unlocking instructions.Using this you can unlock your phone from Network lock easily.
Nokia 3200
Answered
on Dec 26, 2013
You got to call your phone company to get your phones puk and avoid guessing cause it could lock up the phone
Nokia 3200
Answered
on Apr 13, 2013
only globe telecom can fix wth ur problem
Nokia 3200
Answered
on Feb 27, 2013
First All Check:1.Confirm whether same sim card is working in other h.s or not.2.Make sure the sim slot is o.k. only try these two.3.If all the above steps fails, check the SIM card connector pins for damage.if so try to get serviced. 4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.u can make it jumper mean u can fix this prob with out sim card is for this contact.5.take sim connector slight up by pin then cheak by inserting sim.6.hot air gun on sim i.c. then cheak it.Last Option:IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service& Sim Office and Get the Duplicate Sim Same Your No From Office OpratorProblem will Solved Quickly
Nokia 3200
Answered
on Aug 31, 2012
Restriction code is nothing but the unlocking code for your mobile.To get the restriction code for your Nokia 3200 model mobile, just visit this site
Unlock-free.com, In this site just give your IMEI number , country & network lock after that within a short period you can get the restriction code for your nokia mobile............I hope this is helpful for you.......
Nokia 3200
Answered
on Jul 09, 2012
