20 Most Recent
Nokia 6800 Questions & Answers
Nokia 6800 smart movies serial number is
Hello and Welcome to FixYa!
Sir/Ma'am if you have misplaced your Key, in case you have bought the Software then you can provide a proof of purchase and they will give you your Key in return.
But IF you are searching for a free key/serial/crack this isn't the right place, as FixYa strongly prohibit such type of activities and keep a record of its customers and experts along with their IP's to avoid any miss use.
I hope you understand.
Concerned, Nooh
10/26/2010 11:07:07 AM •
Nokia 6800
Answered
on Oct 26, 2010
Nokia 6800
there are connector for left side kepad. those connecter are on the head of phone, u locate them hold ur phone vertically from the button which power on ur phone above that button on head of ur phone on the both corners u will see four golden small strips, with pair of 2 on both sides. there can be some kind of rusting on strips , rub them with needle, then check ur kepad if problem still stays then may be ur left keypad is not making connection with those strips contact any technician
12/7/2008 10:01:19 AM •
Nokia 6800
Answered
on Dec 07, 2008
File format not supported
some files canneot be readable with nokia phones u need softawres to make ur phone ve tha abilty
if its a PDF insatll a an pdf reader or if its a wma try install a music player thats suppoet that type of formats
plz do rate this post
use pcsuite and
www.mobile9.com
10/15/2008 10:35:06 PM •
Nokia 6800
Answered
on Oct 15, 2008
No dil
hi i can get you the unlock codes but i need to know what country and network the phones locked to and also the imei number you can get the number by pressing *#06# or its printed on back of phone under the battery and looks like 12345/123/1234566 ots 15 numbers long once i have this info i can generate your unlock codes ok
4/16/2008 10:34:03 AM •
Nokia 6800
Answered
on Apr 16, 2008
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
