what is a moto?what is a G9car,boat , motorcycle or what? moved yahwhat is an ACCU?a telephone, cell phone, the battery died/?well post too cell phones not cars OK?moto = Motorola?wowat random I find this at youtubelearn to use youtube any CELL works. or wreck the phone you will.some are crazy hard to do.took me 10seconds labor (googling) for you.https://youtu.be/PNM50W-wf9A
The Motorola XPR 7550 can be programmed by using the RJ11 port in the back of the Motorola Impres Charger WPLN4243A. The WPLN4243A charger has a built-in interface that allows you to program your radio using the Motorola CPS software. This is done by connecting the charger to a computer via the USB cable, and then connecting the radio to the charger using the RJ11 programming cable. Once connected, the radio can be programmed and its firmware can be updated using the CPS software. It's important to note that the CPS software is not included with the charger and must be purchased separately. It's also important that you have the right version of CPS software that corresponds with your radio's firmware version.
To access the setup menu on a Motorola DCX700 cable box, you will need to press the "Menu" button on your remote control and then use the arrow keys to navigate to the "Settings" or "Setup" menu. Depending on the specific model of your cable box and the version of the firmware it is running, the exact steps for accessing the setup menu may vary.
If you are having trouble accessing the setup menu on your Motorola DCX700 cable box, you may want to try the following:
Check the user manual or documentation for your specific model of the cable box to see if there are any specific instructions for accessing the setup menu.
Make sure that you are pressing the correct button on your remote control. The "Menu" button is usually located near the center of the remote and may be labeled with the word "Menu" or with a symbol that looks like a hamburger.
If you are using a universal remote control, make sure that it is programmed to work with your cable box. You may need to refer to the manual for your universal remote to find out how to program it to work with your cable box.
If you are still having trouble accessing the setup menu, you may want to try resetting your cable box to its default settings. To do this, you will need to unplug the power cord from the back of the cable box and then plug it back in. This should reset the cable box to its default settings and allow you to access the setup menu.
To perform network unlocking on a Motorola Moto G6 XT1925, you will need to obtain an unlock code from your mobile service provider or from a third-party unlocking service. Network unlocking is the process of removing the lock that your mobile service provider places on your phone, which prevents it from being used with other mobile service providers.
To unlock your Motorola Moto G6 XT1925, follow these steps:
Contact your mobile service provider and request an unlock code. You may need to provide them with some information, such as your phone's IMEI number and your account details.
If your mobile service provider is unable or unwilling to provide you with an unlock code, you can try a third-party unlocking service. There are several online services that offer unlocking services for a fee.
Once you have obtained an unlock code, power off your phone and remove the SIM card.
Insert a SIM card from a different mobile service provider into your phone.
Turn on your phone and enter the unlock code when prompted.
Your phone should now be unlocked and able to be used with any mobile service provider.
Note: Some mobile service providers may charge a fee for providing an unlock code, and third-party unlocking services may also charge a fee. Additionally, unlocking your phone may void your warranty or cause other issues, so it is important to be aware of the potential risks before proceeding.
Look in the Phone app settings menu.
Google found a link to fixing call barring for the Motorola G8 Power Lite, https://deviceguides.vodafone.co.uk/motorola/moto-g8-power-lite-android-9-0/calls-and-contacts/turn-call-barring-on-or-off/ . From the home screen, press the phone icon. Press the menu icon. Call barring is under Settings > Calling Accounts > the name/id of the SIM card > Call Barring. Select Turn On or Turn Off. You will be prompted to enter a PIN. (A default PIN is given in the document above; advance through the pages.) Then press the Turn On or Turn Off button.
On other Moto devices, you need to press options and then Settings. Then skip the SIM ID step.
I hope this helps. Call barring may be an option your cell provider makes available and hidden by default on the Motorola base code.
Please check with metro (by tmobile) to see if you they still have the ability to provide a sim card for that phone. If not, then you would need to reach out to a cell-phone company tends to work with seniors because seniors would be most likely to use the phone that you've mentioned. One brand in this category is Consumer Cellular. Thank you.
why would you spend money on an account an phone that does not exist. Personally I would ignore ire it. I get emails telling my bank account (that does not exist) is locked, I have charges on my amazon account (that does not exist) telling me call and give them the bank info. It is your money.
