20 Most Recent Hotpoint WMA44 Front Load Washer Questions & Answers
0answers
0answers
Keeps overheating plug
Plug will only overheat if you have a loose connection of some type. Check the connections in the plug - the wires must be tightly connected to the pins and must not be screwed down onto the cable insulation. Check the fuse carrier in the plug - make sure it holds both ends of the fuse securely. Also check the fuse carrier components are securely fixed (usually with a screw or a rivet) to the pins of the plug. If it still overheats the bad connection could be due to a bad wiring connection to the socket it is plugged into or even a bad component within the socket itself. Components in the socket are not repairable - Replace with new.
12/11/2013 11:22:31 PM • Hotpoint WMA44... • Answered on Dec 11, 2013
Motor?
The problem could be with your pressure switch. Click for help on this site regarding change/check of hose connected with pressure switch. Enter your brand and model number of machine.
4/21/2013 10:20:42 AM • Hotpoint WMA44... • Answered on Apr 21, 2013
0answers
How do I remove the motor on a Hotpoint WMA44?
To remove motor.From under the machine, unplug the wiring connector from the motor socket. Remove the push on earthing cable from rear of motor. Remove the two bolts from the motor via the rear panel of the machine. The whole of the motor motor needs to be pushed backwards to disengage the three mounting pegs from their plastic sleeves. I used a wide bladed screwdriver to lever the motor from its mounting position at each of the three pegs. The motor will come away from the washing machine but don't let it drop, support it. Remember it is small but for its size it is heavy! Good luck
2/12/2012 11:25:08 PM • Hotpoint WMA44... • Answered on Feb 12, 2012
Cannot separate plastic tub from the metal drum
this is rust from brearings and it can be a bit of a sod to get bearings out sometimes the breaings get stuck on the drum shaft due to rust and a new shaft will be needed if drum and shaft are out put wd40 on breaings and let soak then try to knock them out if the breaing breaks in the drum then a new drum will be needed if that happens i would bye new machine as some machines are cheeper then all the parts needed to fix
2/6/2012 10:25:29 PM • Hotpoint WMA44... • Answered on Feb 06, 2012
Washing machine making a knocking sound
On this washer the problem is the washer drum rear bearing is worn out, a common problem and often caused by not using the correct detergent for a front loader, detergent is very corrosive, so special types are used in front loads to prevent soap residue corroding the drum bearing. Once the bearing go out then the struts that cushion the drum during the spin quickly follow.
1/31/2012 5:02:10 PM • Hotpoint WMA44... • Answered on Jan 31, 2012
Can move the drum as
If you have necessary tools to remove & fix the bearings you too can do it. The only problem lies is alignment of the bearings. There are two bearings involved. If any one is not aligned with the another one, you will need new bearings again in a span of 3 to 6 months. To carry out this work you will need spanners, hammer, wrenches. The persons who have carried out mechanical jobs can do it easily. After fitting the bearings the drum should have free movement when rotated by hand. It should not stop abruptly, but slowly.
12/7/2011 12:56:04 PM • Hotpoint WMA44... • Answered on Dec 07, 2011
When my machine gets onto the 'rinse and
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
8/30/2011 2:03:22 PM • Hotpoint WMA44... • Answered on Aug 30, 2011
Machine will not work because the door lock light
change the door switch
7/7/2011 5:05:15 PM • Hotpoint WMA44... • Answered on Jul 07, 2011
Door lock light flashes and machine won't
There may be a fault on the control board. I have had instances of PCB tracks burning out on Hotpoint machines. This is not something you can fix unless you have some electronics experience (unless you replace the whole control board).
6/8/2011 12:03:19 PM • Hotpoint WMA44... • Answered on Jun 08, 2011
Wma44 wont complete rinse and
Have you managed to check the drain motor/pump for correct operation?
Here are my (sorry- pre-typed!) complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
5/4/2011 7:20:33 PM • Hotpoint WMA44... • Answered on May 04, 2011
2answers
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
4/4/2011 6:36:05 AM • Hotpoint WMA44... • Answered on Apr 04, 2011
Hotpoint WMA44 Front Load Washer Logo
55 questions posted
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
washing machine making knocking sound
  • Washing Machines
