20 Most Recent HP 2025 20.1" Flat Panel LCD Monitor Questions & Answers
I have no problems by
talk to your adapter maker, (hdmi)??? and Grundig? adaptor is not from HP so , how can HP help here? my guess, is the Grundig does not support this device ask Grundig? this? but tell them what adapter it is, first. full name and model, and source, and then there is hope. or find a video car that supports HDMI direct.? what is Hp2025, HP says its a printer. what is it, you imply its a PC, what PC, desktop it seems even google can un tangle what is a 2025 just a clue. post like this. what do you have now, name the parts. all of them. (on topic) full names, and full model numbers Operating system used. (windows? linux?) the state what dont work (HDMI on Grundig, bla bla.) watch google , go batty https://www.google.com/#q=Hp2025 the HP has a service tag with full model on it what might that be?
5/13/2017 1:42:49 PM • HP 2025 20.1"... • Answered on May 13, 2017
2025 shows power light but doesn't respond to
hi
check if cables are connected
12/18/2010 6:51:28 AM • HP 2025 20.1"... • Answered on Dec 18, 2010
Can not get the menu for monitor setting to stop
maybe one of the buttons is stuck? a short circuit in the button is definite to cause that... i shocked my last monitor and it started doing that. I had to buy a new monitor, because my tech couldn't fix it because it was arcing
9/27/2009 8:11:57 PM • HP 2025 20.1"... • Answered on Sep 27, 2009
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
4/27/2009 10:13:10 AM • HP 2025 20.1"... • Answered on Apr 27, 2009
Everything is too bright
I have a similar issue. Opened up the unit and found that a module on the power board had a small bit of the insulation melted, meaning that that module is overheating. It's just a matter of time before that module shorts out and the screen goes blank. The power board needs replaced.
2/26/2009 8:57:05 PM • HP 2025 20.1"... • Answered on Feb 26, 2009
Resolution
it is definatley something to do with the graphics card. Or just the settings you have set it to. Have you tried pressing the auto set button on the monitor itself to see what happens? other to that if you can set the display settings to 1680 by 1050 and display it to highest 32bit. If it doesn't let you do this then you definatley have graphics card issues.
11/3/2008 12:59:42 PM • HP 2025 20.1"... • Answered on Nov 03, 2008
Trying to hook this monitor to dell inspiron 6000
You always need a driver for things to work. Look in your device manager.
Right click (my computer) go to properties then device manager and look at you video to see if there is a question mark for the driver.
Sounds like it might be getting too hot and/or going bad. Not sure how to diagnose this without seeing it myself. That is the best that I can do. Your video card could be going bad. Try another video card on that monitor. This will be the only way to decide if it is the card or monitor. Try it on another machine and see what it does.
6/11/2008 9:51:00 PM • HP 2025 20.1"... • Answered on Jun 11, 2008
2answers
HP 2025 20.1" Monitor
Unfortunately, the LCD screen of any screen is always the most expensive part of the monitor, and it usually costs as much as the monitor itself to buy, not including shipping and replacing (unless you plan to replace it yourself). I could not find any replacement screens myself, and they are very hard to find. My suggestion is to just buy a new one. Sorry.
4/2/2008 12:33:09 PM • HP 2025 20.1"... • Answered on Apr 02, 2008
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
Hp supply central pin connected to the 19V power
  1. Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
  2. Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
  3. Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
  4. Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
  5. Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
3/30/2024 8:53:24 PM • HP Computers &... • Answered on Mar 30, 2024
3answers
I got a 4 year HP laptop and it show a black screen and if I press Esc it will say Esc..start up and will do the same F2 and others.
If your laptop starts but the screen remains black, this video shows you the troubleshooting steps to follow:
3/27/2024 7:16:54 AM • HP Computers &... • Answered on Mar 27, 2024
What kind of screws open the backside of an HP Envy PC
The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/13/2024 5:33:03 PM • HP Computers &... • Answered on Mar 13, 2024
How do I open the back of an HP Envy PC, and What kind of screws open the back please.
Great questions, but two questions edited into one. The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/12/2024 6:00:48 PM • HP Computers &... • Answered on Mar 12, 2024
2answers
What to try now hp omen dv7 battery issue
If calibrating the battery didn't work for you you could try a hard reset of the battery:
3/6/2024 9:11:06 PM • HP Computers &... • Answered on Mar 06, 2024
2answers
I have installed 4G RAM, Is that the MAX supported or may upgrade to more ?
Memory Max Maximum supported = 8GB
2/17/2024 5:55:53 AM • HP Computers &... • Answered on Feb 17, 2024
3answers
I have an HP Pavillion533w that will not turn on when I press the power button.
Here are troubleshooting steps for when your computer won't start:
2/15/2024 7:54:52 PM • HP Computers &... • Answered on Feb 15, 2024
HP 2025 20.1" Flat Panel LCD Monitor Logo
17 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
not get menu monitor setting stop
  • Computers & Internet
