20 Most Recent HP L1902 19" LCD Monitor Questions & Answers
When monitor is switched on,it
Look for bad caps, same as other failed monitors as shown in my albums here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
8/23/2010 12:51:21 AM • HP L1902 19" LCD... • Answered on Aug 23, 2010
I need a new lcd screen. What is the part number
it should be all written on the box or bottom/back of the screen in a service label. every electrical part have that.
9/22/2009 12:45:13 PM • HP L1902 19" LCD... • Answered on Sep 22, 2009
2answers
L1902 19" lcd monitor power problem?
no stays completely blank. yes it is my pcs monitor
11/1/2008 2:42:25 PM • HP L1902 19" LCD... • Answered on Nov 01, 2008
Blackout
Try lowering your brightness setting below 55.Its hard to see at just the right angle.The monitor has a failsafe installed for over voltage use of the bulbs for the screen. The lights go out but your screen is still there.
8/11/2007 4:58:46 PM • HP L1902 19" LCD... • Answered on Aug 11, 2007
Blank Screen
Can you see anything at on but dimly? If so thats is the backlight tube If you cannot see anything then it is a major fault eitherway a repair shop job I should think
5/31/2007 9:30:32 AM • HP L1902 19" LCD... • Answered on May 31, 2007
HP CP4525 hungs with 49.FF03 device failure
If your HP CP4525 printer is hanging on every restart with the error code 49.FF03 device failure, it may indicate a problem with the printer's hardware or firmware. Here are some steps you can try to fix the problem:
  1. Restart the printer: Try restarting the printer to see if the issue is resolved. To restart the printer, turn it off and unplug it from the power outlet. Wait a few minutes, then plug it back in and turn it on.
  2. Check for firmware updates: Make sure that the printer has the latest firmware installed. You can check for updates on the HP website or through the printer's web-based interface.
  3. Check for hardware issues: Check the printer for any visible damage or issues with the hardware. Make sure all the cables and connections are secure and not damaged.
  4. Reset the printer: If the above steps do not help, you may need to try resetting the printer. To reset the printer, turn it off and unplug it from the power outlet. Then hold down the power button for 30 seconds and release it. Wait a few minutes, then plug the printer back in and turn it on.
If none of these steps help, you may need to contact HP or a technical support team for further assistance. It is also a good idea to check the documentation or manual that came with the printer for any troubleshoot
1/22/2023 10:30:48 PM • HP Computers &... • Answered on Jan 22, 2023
2answers
How do I fix my hp pavllion p7 to get windows 11
Which specific model do you have? The latest CPU (A10-5800K) that is compatible in the P7-1587 was released by AMD in 2012. The Intel version, P7-1597c, takes an Ivy Bridge or Sandy Bridge processor. That's second or third generation Intel Core, among others. Windows 11 CPU support list for AMD processors is here: https://learn.microsoft.com/en-us/windows-hardware/design/minimum/supported/windows-11-supported-amd-processors . Most of the supported CPUs were released in 2018 or later. For Intel processors, you need a eighth generation Intel Core processor (Amber Lake or similar era Intel CPU) or newer. You'd need a new motherboard, CPU with TPM and memory. If you want Windows 11, buy or build a new computer. I hope this helps. Cindy Wells
1/17/2023 8:45:47 PM • HP Computers &... • Answered on Jan 17, 2023
2answers
Free download music for pc
music download software http://100-downloads.com/download.php?p=682 spotify Instant and legal access to over 10 million music tracks http://www.artistdirect.com/music http://mobile.afreecodec.com/free-songs-download-87079.html once the music starts to download a browse option will open where you will need to select if you want to run or safe
you should always keep your antivirus up to date when using any file sharing programs on the internet
hope this helps
1/17/2023 6:56:16 AM • HP Computers &... • Answered on Jan 17, 2023
How do I find out if my HP Elitebook 8470p has bluetooth?
well that is simple, in concept the Bluetooth on this series has 2 kinds of ways. the most common is, Bt IS PART OF THE WIFI CARD AMAZING IS, THE FACT THAT THE HP, SERVICE GUIDE COVERS ALL THIS AT HP..COM, HP DOT COM. A COMPLEX URL, NO? I OWN 8540W So know them well the card BT is a seperate card here, narrow. and has its own socket, see them used on ebay, just by one . now the gotcha it has special cable so if your PC never had BT ,yes you need the cable too.. seen here clearly https://www.manualslib.com/manual/1123083/Hp-Elitebook-8470w.html?page=81&term=Bluetooth+Module&selected=1#manual
1/10/2023 12:48:43 PM • HP Computers &... • Answered on Jan 10, 2023
I want to fix the door of my HP Officejet J5783 so that it will close properly.
If the door of your HP Officejet J5783 printer is not closing properly, there may be a few possible causes for the issue. Here are some steps you can try to fix the problem:
  1. Check for debris: Make sure there is no debris or foreign objects blocking the door from closing properly. Remove any debris or objects that may be causing the issue.
  2. Check the hinges: Check the hinges of the door for any damage or looseness. If the hinges are damaged or loose, try tightening them or replacing them if necessary.
  3. Check the alignment: Make sure that the door is properly aligned with the printer. If the door is not aligned properly, try adjusting the alignment.
  4. Check the door latch: Check the door latch for any damage or looseness. If the door latch is damaged or loose, try tightening it or replacing it if necessary.
  5. Check the printer software: Make sure that the printer software is up to date and that there are no conflicts with the door. You can check for updates on the HP website or through the printer's web-based interface.
If none of these steps help, you may need to contact HP or a technical support team for further assistance. It is also a good idea to check the documentation or manual that came with the printer for any troubleshooting tips or recommendations.
12/21/2022 8:00:58 PM • HP Computers &... • Answered on Dec 21, 2022
Where do I download the alexa app on windows 10
To download the Alexa app on a Windows 10 PC, you can follow these steps:
  1. Open your web browser and go to the Amazon website.
  2. Click on the "Account & Lists" drop-down menu in the top right corner of the page and select "Your Devices" from the list.
  3. Click on the "Add Device" button and select "Alexa Devices" from the list.
  4. Choose "Alexa App" from the options and click on the "Download" button.
  5. The Alexa app will start downloading. Once the download is complete, click on the "Run" button to start the installation process.
  6. Follow the prompts to complete the installation process.
  7. Once the Alexa app is installed, you can launch it and link it to your Echo Dot by following the on-screen instructions.
Alternatively, you can also download the Alexa app from the Microsoft Store. To do this, follow these steps:
  1. Open the Microsoft Store app on your Windows 10 PC.
  2. Search for "Alexa app" in the search bar.
  3. Click on the "Alexa" app from the search results and select "Get" to start the download.
  4. Once the download is complete, the Alexa app will be installed on your PC and you can launch it and link it to your Echo Dot by following the on-screen instructions.
12/21/2022 8:00:56 PM • HP Computers &... • Answered on Dec 21, 2022
Instruction referenced memory
The error "Instruction referenced memory 0x40028e28 referenced memory at 0x00000000" may indicate that the program you are using is trying to access memory that is not allocated or has been corrupted. This can be caused by a variety of factors, including software conflicts, hardware issues, or malware. Here are some steps you can try to fix the problem:
  1. Restart the device: Try restarting your device to see if the issue is resolved.
  2. Check for updates: Make sure that all the software and drivers on your device are up to date. Installing any available updates may fix the issue.
  3. Check for malware: Run a malware scan to check for any malicious software that may be causing the issue.
  4. Check for hardware issues: Check for any hardware issues that may be causing the problem. This can include damaged or failing hardware components, such as the memory or hard drive.
  5. Repair or reinstall the software: If the above steps do not help, you may need to try repairing or reinstalling the software that is causing the error. Make sure to follow the instructions provided by the manufacturer or technical support team to properly uninstall and reinstall the software.
If none of these steps help, you may need to contact a technical support team for further assistance. It is also a good idea to check the documentation or manual that came with the software or device for any troubleshooting tips or recommendations.
12/21/2022 8:00:48 PM • HP Computers &... • Answered on Dec 21, 2022
My hp laptop does not show SKIP DRIVE on the screen option
use cmd option
12/18/2022 7:23:08 PM • HP Computers &... • Answered on Dec 18, 2022
Password of HP LE1901w monitor
It is unlikely that your HP LE1901w monitor has a password, as monitors do not typically have password protection. If you are unable to access the settings or menu on your monitor, it may be due to a different issue, such as a faulty control panel or a problem with the cable or connection to the computer. To troubleshoot this issue, you can try the following steps:
  1. Check the connections between the monitor and the computer to ensure they are secure and functioning properly.
  2. Try using a different cable or a different input on the monitor to see if the problem persists.
  3. Check the monitor's control panel and buttons to see if there is any damage or if they are not functioning properly.
  4. If the problem persists, you may need to contact the manufacturer or a qualified technician for assistance.
If you are unable to access the settings or menu on your monitor, you may want to consult the user manual or contact the manufacturer for further assistance.
12/10/2022 5:18:55 PM • HP Computers &... • Answered on Dec 10, 2022
I need help with repairing HP z74 CRT monitor with power failure...
If your HP z74 CRT monitor is not turning on, there could be several potential causes. Some common causes of power failure in CRT monitors include:
  • A faulty power supply: The power supply is responsible for providing power to all the components of the monitor, so if it is not functioning properly, the monitor will not turn on. You can test the power supply by using a multimeter to measure the voltage at the output connectors. If the voltage is not within the expected range, the power supply may need to be replaced.
  • A faulty flyback transformer: The flyback transformer is a critical component of a CRT monitor, as it converts the high voltage AC input from the power supply into the low voltage DC output required by the other components of the monitor. If the flyback transformer is faulty, the monitor will not turn on. You can test the flyback transformer by using a multimeter to measure the voltage at the output terminals. If the voltage is not within the expected range, the flyback transformer may need to be replaced.
  • A faulty or blown fuse: The fuse is a safety device that protects the monitor from damage due to excessive current. If the fuse is blown, the monitor will not turn on. You can test the fuse by using a multimeter to measure the resistance across the fuse. If the resistance is very high or infinite, the fuse is blown and will need to be replaced.
To diagnose the specific cause of the power failure on your HP z74 CRT monitor, you may need to open the monitor and perform some basic tests using a multimeter. This will help you identify the specific problem and take the appropriate steps to fix it. It is important to note that working on electronic equipment can be dangerous, so if you are not familiar with electronics repair, it is best to seek the assistance of a qualified professional.
12/10/2022 2:30:44 AM • HP Computers &... • Answered on Dec 10, 2022
2answers
How could I connect my home WiFi to my HP computer
wifi is not a proxy,go into your internet settings and change it to connect automatically,not proxy
12/8/2022 5:20:41 PM • HP Computers &... • Answered on Dec 08, 2022
2answers
Hy... I have an HP Pavilion dv7-2155eg and the
you left out 2 facts when DID it last work ok on this LT. never, last year , 2008 or what, my guess NEVER ! no OS stated, W7? what? and MUST MATCH !!! drivers !!! facts the product is 100% dead now at HP, no support at all . period they will just quip "legacy" sorry.. https://h30434.www3.hp.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=xb3000 you have the wrong dock. here is the old data sheet it tell you only these PC work The xb3000 Notebook Expansion Base is compatible with all HP Pavilion dv2000, dv6000, dx6000, dv9000, tx1000, tx2000 and Compaq Presario V3000 and V6000 series notebooks. this is what you have. http://h10032.www1.hp.com/ctg/Manual/c01686692.pdf shows xp last supported OS back then then.2008 but? more lots more, you can search at HP all day but NO OS STATED BY YOU and why you think your PC runs on this X the last post at HP said HP 15-r264dx does not have docking port, you have to use USB "dock" such as HP USB 2.0 or USB 3.0 docking stations. and last here is your correct docking station (you never asked first) https://h10057.www1.hp.com/ecomcat/hpcatalog/specs/provisioner/05/KN745AA.htm KN745AA - HP Notebook QuickDock so let me guess the real story i found this docking station at a garage sale for $5 what does it FIT answer, see link 2 above , PDF for the data sheet, ever like just google ? here is 1 hit, found the service guide. 2006(11 years old) http://h10032.www1.hp.com/ctg/Manual/c01103327.pdf page 6 shows it dont work on your PC. so that 2 books that said that. if does not mention OS, but 2006 we know is XP , never run XP ever. there are rumors of hacks that can make it work but only no details. for sure it must be a hardware match. then you need drivers to run it, but if your OS is not XP finding them now is very very hard. only google can find them and I see ZERO
12/7/2022 11:29:09 AM • HP Computers &... • Answered on Dec 07, 2022
HP L1902 19" LCD Monitor Logo
11 questions posted
Top HP Computers & Internet Experts
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
need new lcd screen part number
  • Computers & Internet
