20 Most Recent
ViewSonic VP201b 20.1" LCD Monitor Questions & Answers
Hi, I have a ViewSonic
Get a working monitor and turn on the computer. Then swap the monitor with VP201b.
Get a flash light closer to the screen to see whether you can see the desktop screen image. Yes? Then it is your backlight inverter.
Find a Youtube video to show you how to open the cover. Then look for any sign of broken capacitor(s). Replace them and then test your monitor. If all capacitors are okay, it is one of your FUSES. There are 2 tiny surface mount fuses ("FN" type). You can short the two ends to test it before removing them. Often only one of them is broken. Replace it and the monitor shall be okay now.
Screen jumps back to prior screen
If you mean to say that the computer-generated displayed image on your screen changes, it's a function of the computer, not the monitor. If you mean to say that some monitor-generated displayed image is appearing (such as a setup/configuration menu or a splash screen), please tell us more so we can diagnose further.
ViewSonic VP201b with a black screen
hramirez, Retevo. com says time to retire this old monitor. Its that or you will need to do some extensive reading here on fixya on how and what to look for inside the unit that could be causing your black screen condition!!! Then you will go to YOUTUBE and view some of the many video clips that deal with "lcd monitor repair" and lcd monitor disassembly". Have you noticed any bad, swollen top, elcetrolytic filter capacitors on the units "switch-mode-power-supply/CCFL inverter printed circuit board?? How about any "cold" frosty looking solder joints around the component leads of the power transistors and ferrite inverter transformers? May need to get large magnifying glass to find those pesky little cold solder joints. 12fixlouie
Display flickers than scrambles.
Most likely loose connection at PC. Check that monitor connector pins are not bent. Ensure that he monitor plug screws are screwed into the connector to prevent plug movement, at the PC and in the case of some monitors, also at the back of the monitor. If this does not correct the problem, there is probably a fracture in one of the solder joints on the VGA board at the connector.
Try eBay for those parts.
Viewsonic VX2835wm monitor that powers up with a good screen for a couple of seconds and then goes blank. I replaced the power board and it still does the same thing. Could it be the on/off switch?
FIRST WE DO NORMAL AND LATER TRUE CAUSE.
gee that is normal on all monitors and by Energy Star laws too.
the monitor if the PC is dead or in speed mode, shuts of in 15 to 90 seconds, all do, every one. the monitor has self sleep, all do. everyone ever made did. even back to CRT days.
and the OSD button goes dead after. that. too. fooling the untrained.
here is the first tests, NO PC connected at all
power on see power light glow correct color
then see Viewsonic splash screen push the menu button now. quickly, if button dead hold it for 10 to 15 second to reverse the button lock now, see OSD works.
if you test the monitor on a good PC not in sleep mode the but working PC, your monitor is ok.
this monitor is very very old, 2004?
it has CCFL back lamps not LED<
and all fully used CCFL lamps are now no good, used 8yrs a day at 5years are no good. that is why we use LED back lamps now.
this is what they do: all do , used fully.
1: goEs dead forever, (vast did)
2: INTERMITTANT . (BINGO YOU ) OR INVERTER DEAD.
3: DIM BULBS (like me. lol)
4 TURN YELLOW FOR WHITE screens.
5: STROBEs. (FLASHes)
AND A VERY EXPENSIVE SURE, THAT. AND LABOR.
3/2/2022 5:23:35 PM •
ViewSonic...
Answered
on Mar 02, 2022
Viewsonic VX2880ML 4K monitor, front vontrols won't work, help.
power on and power on led glows normal , not yellow or flash.
then this happens splash. attached, 2014 made.
then that tells you screen is NOT DEAD is it? now? here?
(PC is dead or missing)
- NO connections on 1 or more inputs.
- NO sync
- no signal
- OUT OF RANGE
and goes black screen NEXT,. if all that fails power supply is bad.
if all that works the menu button works for 15 seconds turned on with no PC, and also works on all PCs if connected to one that are all good and not sleeping. test the monitor on 2 PCs if confused.
3/2/2022 4:55:16 PM •
ViewSonic...
Answered
on Mar 02, 2022
My new Viewsonic VX monitor shows "no signal" when connected to computer.
that means just what it tells you
the PC is dead, PC video dead or video cable unplugged , dog chewed it , pins bent or plugged in wrong on 1 or both ends.
or monitor not selected to the correct input port (OSD)
PC power lamp glowing not amber or blinkikng
PC fans spin , PSU fan and CPU both
if PC has GPU card in PCI-express slot it must be use those ports only for video.
PC not beeping
PC not texting errors post.
PC not blinking codes on LED or caps lock or POST ERRORS !
NO PC told
PC dead.
PC not stuck in sleep mode , hold PC power button for 10 full seconds to end it, (cold boot that is)
test monitor on end good PC? yet?
3/2/2022 4:54:28 PM •
ViewSonic...
Answered
on Mar 02, 2022
