20 Most Recent ViewSonic E70fb (Black) 17 in.CRT Conventional Monitor Questions & Answers
Monitor (viewsonic e70fb) keeps shutting itself off
the screen has begun vibrating and is very hard to read.
it sounds me that there is some sparking in power supply or high voltage section (FLYBACK) due to loose contact,
your problem of  shut off, I would turn it back on and it would stay on
.might be also due to that only.
please call tech if you are not a tech person.
it is not a major one & simple to fix.
good luck.
1/1/2014 4:05:35 AM • ViewSonic E70fb... • Answered on Jan 01, 2014
I have Viewsonic E70fB monitor.
u should change all of ur push switches at front pannel
7/1/2013 9:42:01 AM • ViewSonic E70fb... • Answered on Jul 01, 2013
My View sonic E70fB displaying
press and keep pressed upto 10 to 20 seconds the unlocked messege will appear problem will be solved
9/12/2011 5:51:53 AM • ViewSonic E70fb... • Answered on Sep 12, 2011
0answers
What is meant by osd
On Screen Display.
It's an on-screen display of adjustments such as brightness and contrast.
9/13/2010 3:51:19 PM • ViewSonic E70fb... • Answered on Sep 13, 2010
2answers
E7oFb viewsonic crt monitor a
I don't know this particular model, but there are a few things you can check should you wish to retain the monitor.
1) If the unit has the older rotating controls, try spraying them with electronics switch cleaner (with lubricant). Work them back and forth a few times with the power off.
2) If the controls are the tact switch type, with the power off, press all of them and you should feel them engage. If not, replace the switches. They should be available generically for about 25-50 cents each.
Dan
9/2/2010 9:52:32 PM • ViewSonic E70fb... • Answered on Sep 02, 2010
My viewsonic monitor is havind problem like
go to toms harwaere.com for viewsonic vx922 problems. Solutions for green power light blinking are there. Solutions say to replace the capacitors
12/6/2009 6:55:12 PM • ViewSonic E70fb... • Answered on Dec 06, 2009
Monitor keeps turning off
ther might be a problem with your grphics card or the sockit on the end of the lead
4/26/2009 9:12:52 PM • ViewSonic E70fb... • Answered on Apr 26, 2009
Black screen
The problem could be in the Monitor, Computer or Cable. Did you try to connect another monitor or can you try to connect another computer (maybe a laptop) to that monitor?
It's important to understand where to start.
Thanks
11/9/2007 2:59:05 PM • ViewSonic E70fb... • Answered on Nov 09, 2007
2answers
My monitor viewsonic VA1932 wm gets electric shock if I touch the VGA,DVI ports and the metal placed in the base
This is a hazard that you need to figure out. First thing is to check the power cables, Some of those monitors use a separate power brick and some dont. IF yours has a power brick, make sure it is made by viewsonic. It maybe a polarization issue with the wrong power unit. If the monitor plugs straight into the power cord and then into the outlet, check the cord ends to see if they are polarized ( one is bigger than the other spade) If they are different sizes where they plug into the wall, there is something more serious wrong inside the unit. You should use an electric meter to see how high the voltage is. IF it is more than 50 Volts you should stop using the unit. That model number is not listed on Viewsonics website. There is one that is close but they are not making it any longer.
1/12/2022 6:33:47 PM • ViewSonic... • Answered on Jan 12, 2022
2answers
ViewSonic VA2261H monitor leaning forward, how to adjust?
hi find link for view sonic user Manual https://cdn.cnetcontent.com/61/f2/61f22225-fb19-4df8-b503-b4cacc6d84ea.pdf
12/31/2021 6:00:29 PM • ViewSonic... • Answered on Dec 31, 2021
VIEWSONIC VX2880ML 4K MONITOR ,FRONT CONTROLS WONT WORK ,HELP
https://support.viewsonic.com/en/support/solutions/articles/33000221575-what-to-do-when-no-display-from-my-monitor-
4/4/2020 1:07:49 PM • ViewSonic... • Answered on Apr 04, 2020
Viewsonic VX2835wm monitor that powers up with a good screen for a couple of seconds and then goes blank. I replaced the power board and it still does the same thing. Could it be the on/off switch?
FIRST WE DO NORMAL AND LATER TRUE CAUSE. gee that is normal on all monitors and by Energy Star laws too. the monitor if the PC is dead or in speed mode, shuts of in 15 to 90 seconds, all do, every one. the monitor has self sleep, all do. everyone ever made did. even back to CRT days. and the OSD button goes dead after. that. too. fooling the untrained. here is the first tests, NO PC connected at all power on see power light glow correct color then see Viewsonic splash screen push the menu button now. quickly, if button dead hold it for 10 to 15 second to reverse the button lock now, see OSD works. if you test the monitor on a good PC not in sleep mode the but working PC, your monitor is ok. this monitor is very very old, 2004? it has CCFL back lamps not LED< and all fully used CCFL lamps are now no good, used 8yrs a day at 5years are no good. that is why we use LED back lamps now. this is what they do: all do , used fully. 1: goEs dead forever, (vast did) 2: INTERMITTANT . (BINGO YOU ) OR INVERTER DEAD. 3: DIM BULBS (like me. lol) 4 TURN YELLOW FOR WHITE screens. 5: STROBEs. (FLASHes) AND A VERY EXPENSIVE SURE, THAT. AND LABOR.
4/4/2020 1:05:14 PM • ViewSonic... • Answered on Apr 04, 2020
How can I unlock osd on my TV viewsonic n2011
OSD Lock: Press and hold [AUTO] and the up arrow for 10 seconds. If any other buttons are pressed the message OSD Locked will display for 3 seconds. OSD Unlock: Press and hold [AUTO] and the up arrow again for 10 seconds. http://www.viewsonicglobal.com/public/products_download/user_guide/Display/VA1903A/VA1903a_UG_ENG.pdf?pass
4/4/2020 1:02:43 PM • ViewSonic... • Answered on Apr 04, 2020
Vx922 capacitors will they work on a viewsonic va1930wm
https://www.youtube.com/watch?v=X6Tn6a_Xy7Y
4/4/2020 1:00:50 PM • ViewSonic... • Answered on Apr 04, 2020
My monitor is all purple and white how do I fix that on a viewsonic
https://www.youtube.com/watch?v=-EfwZnWYrvI
4/4/2020 12:57:32 PM • ViewSonic... • Answered on Apr 04, 2020
How to remove back panel of viewsonic va2046
Hello Edelberto, this monitor does not disarm by the back to disarm the monitor, you have to remove, with great care, the front frame and there you will see the obstacles you have to remove the panel assembly and the platelets I hope you can disarm it, comment the results Greetings Franco Dosil Hola Edelberto,este monitor no de desarma por la parte posterior para desarmar el monitor, tienes que retirar, con mucho cuidado, el marco frontal y ahi veras las trabas que tiene para sacar el conjunto del panel y las plaquetas Espero que puedas desarmarlo, comenta los resultados Saludos Franco Dosil http://www.viewsonicglobal.com/public/products_download/36/29622.pdf http://www.viewsonicglobal.com/public/products_download/36/29639.pdf
5/13/2019 1:16:45 AM • ViewSonic... • Answered on May 13, 2019
Viewsonic vx922 capacitor compaiable va1930wm montor
As long as they are the same value
4/18/2019 6:31:34 PM • ViewSonic... • Answered on Apr 18, 2019
ViewSonic E70fb (Black) 17 in.CRT Conventional Monitor Logo
22 questions posted
Top ViewSonic Computers & Internet Experts
Ekse
tom walsh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Computers & Internet
Most Popular Question
meant osd
  • Computers & Internet
