20 Most Recent JBL Toyota Cd Cassettetape Radio 6 Cd Changer 04 - 06 Camry 20 Pins Premium Questions & Answers
No user serviceable parts! If not working just replace!
JBL Car Audio &... | Answered on May 14, 2020
Bad or shorted voice coil on sub maybe. If you have two subs try them one at a time to see if it goes into protect mode. Whatever sub does it is bad.
JBL Car Audio &... | Answered on Oct 04, 2016
It is very dependent on your vehicle and whether you are using the built-in amp of the head unit or a separate amp. Ideally, I would recommend a good 6.5" component set.
JBL Car Audio &... | Answered on Sep 20, 2016
You need to calculate the amount of amps being driven through that fuse + the amount you need to feed the amplifier.
In my Volvo S40 and V70 I had no problems driving an amplifier of the rear power connector, but on my Honda S2000 however I had to create a different connection all the way to the battery line for a smaller amp (connection as in cables, condensers/filters and fuses).
JBL Car Audio &... | Answered on Feb 22, 2016
single channel about 1kW output power. About $250 when new.
Specs here
http://www.crutchfield.com/S-dVhyYWWFkBd/p_115GTO1201/JBL-Grand-Touring-Series-GTO1201-1-II.html
JBL Car Audio &... | Answered on Aug 26, 2015
Use a C or D size battery. Get two pieces of wire. Strip each end. Wire one end of each to the sub. The other ends you will place one on the top of the battery and, one on the bottom of the battery. If the cone moves outward, you have the correct polarity. If the cone moves inward(toward the back of the speaker) then you have the polarity backwards
JBL Car Audio &... | Answered on Jul 03, 2015
JBL Toyota Cd Cassettetape Radio 6 Cd Changer 04 - 06 Camry 20 Pins Premium Logo
5 questions posted
Top JBL Car Audio & Video Experts
Marvin
Marvin
montehammons
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JBL Car Audio & Video
Most Popular Question
just jl 500 1 installed 2 jbl single
  • Car Audio & Video
