20 Most Recent
Compaq MV 740 17" CRT Monitor Questions & Answers
No power when powered on
Please make sure that the monitor is connected to a good power source and make sure you press the power button ON, If you have done both and the monitor is not coming up, i would suggest you get a new one since CRT are not that expensive,if you try take it to a repairer it might cost you more and do not try and repair it on your own because it contains a large capacitor that stores large amount of charges which is dangerous.
Regards
My monitor does not have any red color to it is
It is very dangerous to work on tv's or monitors without the proper training. They hold voltage even after they are turned off and unplugged, enough to seriously injure someone. There are however adjustments that can be made once you crack open the casing, but if it has already lost color, it will only continue to lose it if you can ever get it set back right again. You best option would be to acquire another monitor. If you want to try it anyway, there are screws in the back of the metal chassis that adjust color, hue, brightness, and shape, that can be adjusted with a small screwdriver.
Can I upgrade my CompaqMV720 computer from Windows ME to Windows XP? If so, how?
I would think that you mast likely can do it. You need a Windows XP disk with a legitimate install key (or Microsoft will give you a hassel). When you are ready to upgrade, turn on or restart your computer and press [Delete] to enter the BIOS. Go to the Boot menu and change the boot order so that your CD/DVD drive is first.
Open the drive and put Windows XP disk in. Press the F10 key to save the changes and exit. when the computer restarts, it will provide several start options. Choose the one that will install Windows XP. From there you just follow the prompts.
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
I want to install xp on compaq nx 6310 give the procedure with pendrive
2006 PC (HP.coM) 16 years old.. ouch.
XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020???
gee google that. 2001 to 2007 was XP rein , vista 2007
I bet there are 1millons of web site still with XP usage .(old topics)
google them. but Microsoft purged theirs.
it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen..
worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC)
to use any relic PCs run LINUX> not XP
