20 Most Recent
Panasonic Palmcorder PV-GS14 Mini DV Digital Camcorder Questions & Answers
Push the reset button
This error indicates a cassette mechanism malfunction.
It happens usually when you don't operate the camecorder for long time
leaving the cassette inside and the battery attached.
Solution:
1. Open the cassette housing and nock GENTLY with your finger tip
on the cassette cabinet (particularly on the position marked "push") until
the cassette is released.
2. Push on the right place (marked "push") to close and then close the
cassette housing
3. Operate the cassette (play, fast forward/backward).
Repeat the above steps several times until the problem is gone.
Advise: Remove the battery and cassette when leaving the camecorder
for long period without being operated, and store the camcorder in a
dust/humidity protected place.
Hope this can help.
12/21/2020 3:57:01 AM •
Panasonic...
Answered
on Dec 21, 2020
The tapes In my Panasonic PV-GS14 are stuck and won't run
you cannot move the spindles/cogs in a mini dv tape without pressing down a small lever on the rear of the cassette.
the lever is in the lower right, move the lever, then move the ribbon protector to the open position, then spin the cogs, the tape should be free.
if not, then you have a jamm inside the cassette, you can open these casettes by removing 4 small screws. ( this is a very fiddly job & you may ruin the casette, if you dont know how )
5/14/2017 6:08:39 AM •
Panasonic...
Answered
on May 14, 2017
How to download video from panasonic nv-gs15 to Computer
first of all you should have your cd driver came with camcorder and as far as i know your driver isnt compatible with vista so better try to use windows xp. install the driver, plug your camcorder using your usb. upload your videos from your camcorder to your pc using ULEAD MOVIE MAKER. edit it and save it with any various types of videos. finish!
CHARCOIS
8/17/2011 2:04:05 PM •
Panasonic...
Answered
on Aug 17, 2011
I can not get the tape out of my camcorder
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
8/17/2011 8:57:15 AM •
Panasonic...
Answered
on Aug 17, 2011
I wish to download video to my harddisc from my ha...
Use
http://www.downloadvideos-convert.com/download-videos-music
1. Download Video Download Studio, install it.
2. Go to the interface, you can download (Automatic capture) the YouTube video there directly. Tab Download to Convert, you can also click "Add" button to upload the videos from computer. You can also edit video by trim and crop functions.
3. After the video display on the Video Download Studio, click "Profile" and choose "General audio", then select an MP3 format. Set destination file, clicking Convert button to complete the task.
Not only convert video to MP3, but also support batch conversion. Safe and easy to operate. No Viruses, No Spyware, No Adware. Do not hesitate. Have a try!
5/24/2010 2:02:18 AM •
Panasonic...
Answered
on May 24, 2010
Raplace a tape roller on a Panasonic Palmcorder
Hello
Thank you for using FixYa for your problem
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
2/21/2010 5:35:28 PM •
Panasonic...
Answered
on Feb 21, 2010
Detection problem of video cam panasonic gs90 ev
Hi
If you're using windows XP, the camera will be automatically identified.
Anyhow, try the following:
1. Check the cable for any possible defects.
2. Switch off the computer.
3. Connect the cable to both the camcorder and the firewire card.
4. Switch on the computer.
5. Switch on the camcorder.
If the cable and the firewire card are both okay then it is possible
that the camcorder firewire interface is damaged.
good luck
12/19/2009 8:52:09 PM •
Panasonic...
Answered
on Dec 19, 2009
I can't get the cassette compartment on my
Hi
Thanks for using FixYa. This issue arises when the Camcorder
is not operated for a long time.
Gently knock on the push button simultaneously opening the cassette holder and
insert the cassette. Now push on the right side and gently push the holder back
in position and press play, fast forward and backward one by one. The Camcorder
will now accept the cassette. If still the issue persists, then repeat the
above steps until the issue is resolved. It is recommended that always store
the camcorder in a dust and humidity free area and always remove the battery
and cassette when not in use.
Please do accept the solution if
the issue is resolved or else revert for further assistance.
Thanks
Rylee
12/17/2009 1:31:41 PM •
Panasonic...
Answered
on Dec 17, 2009
Push the reset switch
open up the LCD screen and on the control panle you will find the reset button in the top right corner get a pin and push the button
4/28/2008 4:44:21 PM •
Panasonic...
Answered
on Apr 28, 2008
