20 Most Recent
Panasonic PV-GS250 Mini DV Digital Camcorder Questions & Answers
I do not see any
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the vewfinder LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
4/29/2011 2:44:22 AM •
Panasonic...
Answered
on Apr 29, 2011
I have several mini tapes
The tape has a brake on the rear of the shell, it's accessed through a small rectangular slot.
Could be faulty or something jammed in the hole.
Place a small screw driver into the slot and carefully see if the brake releases OK.
It should move freely as it's spring loaded.
4/22/2011 5:19:00 AM •
Panasonic...
Answered
on Apr 22, 2011
I have a Panasonic PV-GS250
There is a flaw in the tape casing that was present during manufacture, since all the others work fine I recommend not using the one you are having issues with, eventually it will jam in the camcorder causing more serious problems that will lead to an expensive repair bill.
4/22/2011 3:55:11 AM •
Panasonic...
Answered
on Apr 22, 2011
Where can I buy a battery for a Panasonic
Have you tried bust buy or circuit city? Most battery specialty shops would probably have one, if not they can order one for you. Check the web for battery replacements!
11/15/2010 9:38:36 AM •
Panasonic...
Answered
on Nov 15, 2010
Mini dv tape won't eject, says push reset button
Thanks for using Fixya.
This error indicates a cassette mechanism malfunction.
It happens usually when you don't operate the camecorder for long time leaving the cassette inside and the battery attached.
You can remove this by following these steps:-
1. Open the cassette housing and nock GENTLY with your finger tip
on the cassette cabinet (particularly on the position marked "push") until the cassette is released.
2. Push on the right place (marked "push") to close and then close the
cassette housing.
3. Operate the cassette (play, fast forward/backward).
Repeat the above steps several times until the problem is gone.
Advise: Remove the battery and cassette when leaving the camecorder for long period without being operated, and store the camcorder in a dust/humidity protected place.
Good luck and have a nice day.
Rating the solution is highly appreciated.
3/30/2010 2:54:58 PM •
Panasonic...
Answered
on Mar 30, 2010
Internal Battery Dead?
Your camera support web page:
http://www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd?N=779832046&Ne=&No=0&Nr=12001&Ns=&Ntk=SupportSearch&URL=vSupportSearch&cmTag=true&catalogI
9/20/2009 4:54:33 PM •
Panasonic...
Answered
on Sep 20, 2009
Switches between modes!
If you would be kind enouph to give me your zip code I will be glad to give you a list of repair man close to you.
12/22/2008 3:44:25 AM •
Panasonic...
Answered
on Dec 22, 2008
