20 Most Recent Daewoo 719BF 17 in.CRT Conventional Monitor Questions & Answers
Monitor colour is ok in the middle circle and on
The CRT has likely become magnetized. On the monitor's main menu there is a "degauss" option. It is the option depicting a horseshoe magnet. Select that option to degauss the CRT, and the color distortion should clear up. If it improves but does not clear up entirely, degauss the CRT again. Is the monitor situated near a magnet (such as a speaker, a subwoofer, or some other source of magnetic field)? If so, either move the monitor away from the magnetic field source or move the magnetic field source away from the monitor, then degauss the CRT by selecting that option from the main menu on the monitor. Was the monitor dropped? If so, a series of electromagnets at the back of the CRT (called the "blue lateral") may have come loose. This is somewhat challenging to align and is best handled by a technician.
7/2/2011 8:15:29 PM • Daewoo 719BF 17... • Answered on Jul 02, 2011
I NEED APOWER CORD FOR DAEWOO L950
I can't find information online about your monitor, so I'll give you a generic answer for all monitors. Almost all monitors use a C13 cord - the same kind used for a desktop computer. Some use a C7 (two-wire, like that used for some name brand laptop adapters) or a C5 (three-wire, used on other laptop adapters) C13 image: 173-0602-e.jpg C7 image: ac15wna-r.jpg C5 image: 173-21103-e.jpg These images were lifted from the Mouser Electronics website (AC Power Cords Mouser ). They also carry C13 cords with right-angled plugs, which may be more convenient with some monitors. There are a very few monitors that use an external power supply, which is like a laptop computer power adapter. If this is the case, the voltage and current requirements for the power supply should be on the label on the back of the monitor, and the only other thing you have match is the plug on the power adapter output cord (it needs to fit the power jack on the back of the monitor). Note: the voltage of the power supply must be the same as that shown on the label (usually 12 VDC) and the current rating must be the same or higher. If you don't see the voltage and current listed on the label, look closely at the power jack - the numbers may be molded into the plastic next to it. It is rare to find a monitor with a permanently attached power cord. If this is the case with yours and it is damaged, do not attempt to splice it outside of the monitor. Put a replacement plug on if the good part of the cord is long enough, and use a good extension cord. Otherwise, you should open up the case and replace the entire cord. You will probably have to get a connector for the part of the power cord inside the monitor also. (If you are good with soldering, you may be able to splice to this connector, using heat-shrink tubing to insulate the connections.)
5/8/2014 4:32:13 AM • Daewoo Computers... • Answered on May 08, 2014
Need windows drivers
Yes, what`s the mainboards name ???Try to seach at the pc manufactures homepage.Good luck
1/13/2013 6:25:42 PM • Computers &... • Answered on Jan 13, 2013
Need driver for windows 7
download from manufacturers website
10/16/2010 3:47:09 PM • Daewoo Computers... • Answered on Oct 16, 2010
I have a daewoo security
Hi
I've fixed this problem on a number of monitors recently, its a very simple and easy to fix problem. But you have to take the monitor apart and replace a few electrolyte capacitors from the power supply board.
A local electronics repairer can repair this for you. or you can do this yourself. Any TV, Video, etc repairer can do this simple repair.
Here is a very good picture of bad and good capacitors I found from another fixya Expert.
Your problem is probably 1 or 2 bad capacitors, you will notice a faulty capacitor from its top, if its not flat / level, then it needs to be replaced.
Replace the capacitor with a same voltage cap, the UF rating has to be the same or it can be higher, but not lower. If for example you have one faulty capacitor in the display its 16V (16 volts) and 1000 UF, you can replace it with a 16V 1600UF capacitor for example. Would recommend to replace with the same value.
Let me know if you need further instructions or if you need help in taking the display apart or if you need anything else. I'm sure I can assist.
9/21/2010 4:10:46 PM • Daewoo Computers... • Answered on Sep 21, 2010
When i power down to standby,and start it back up,
is there a "wake up" key on your keyboard? if yes,try using that?
2/4/2010 12:56:00 PM • Daewoo Computers... • Answered on Feb 04, 2010
New fuel pump isnt working
That's because Monitors don't have fuel pumps.
10/13/2009 3:17:41 PM • Daewoo Computers... • Answered on Oct 13, 2009
2answers
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/25/2024 6:13:32 PM • Computers &... • Answered 2 hours ago
4answers
WHAT IS THE E MAIL FROM ECO BANK ALL ABOUT
Could be a phishing attempt, unless you have an account with that bank.
4/25/2024 5:54:17 PM • Computers &... • Answered 2 hours ago
4answers
How to Install YouTube DL.py to Download YouTube Videos to my PC?
Actually, you just need the help of a YouTube Downloader. If you still need help, why not try this YouTube/Video Downloader? Leawo YouTube Downloader acts far more than a single online video downloader to download YouTube videos and other online videos from various video sharing sites like Facebook, Dailymotion, AOL, iFilm, Myspace, Dailymotion, etc. Besides the ability to download online flash videos, this FLV downloader could also acts as video download accelerator to speed up online video downloading, video accelerator to speed up video buffering for smooth playback, video player to play back videos, and IE browser to browse online videos for free downloading. It could extract audios out of online videos, like converting YouTube video to MP3. Hope it can be another choice for you or other users. :) Watch online videos offline freely with Leawo YouTube Downloader
4/25/2024 8:54:44 AM • Computers &... • Answered 11 hours ago
What is digital marketing?
Digital marketing, or “online marketing,” is a form of advertising that uses the internet and digital technologies to connect with customers. Digital marketing seeks to accomplish the same thing as traditional marketing except by leveraging computers, smartphones, and other digital devices rather than traditional media, such as print, radio, or television.
4/25/2024 7:57:08 AM • Computers &... • Answered 12 hours ago
Where can i get mastering machine learning Tips for Tackling Assignment
Here
The Ultimate Guide to Conquering Machine Learning ...
makexyz.com https://www.makexyz.com > the-ultimate-guide-to-conqu... Feb 19, 2024 - When diving into machine learning assignments, it's essential to adopt a systematic approach. Break down the task into manageable components, ...
7 Steps to Mastering Machine Learning with Python in 2022
KDnuggets https://www.kdnuggets.com > 2022/02 > 7-steps-masteri... Sep 30, 2022 - Step 1: Learn Programming for Machine Learning ... You need to have a working knowledge of programming before you dive into machine learning. Most ...
Machine Learning Assignment Help
Medium · Abnerassignmenthelp 1 month ago Our experts can assist you in tackling machine learning assignments effectively. Deep Learning Assignment Help: Our team of deep learning . ..
4/24/2024 8:11:03 PM • Computers &... • Answered Yesterday
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered Yesterday
Upgrades software
If you want to upgrade your software for example your operating system. Your systems unit support only for windows 7, windows 8 and windows 8.1. You may visit this website to download the latest driver for your operating system installed. http://support.lenovo.com/en_PH/downloads/detail.page?DocID=DS035527
4/22/2024 1:20:20 PM • Computers &... • Answered 3 days ago
2answers
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
4/21/2024 5:41:42 AM • Computers &... • Answered on Apr 21, 2024
2answers
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
4/21/2024 4:20:47 AM • Computers &... • Answered on Apr 21, 2024
Daewoo 719BF 17 in.CRT Conventional Monitor Logo
Popular Tags
1 questions posted
Top Daewoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Computers & Internet
Most Popular Question
monitor colour ok in middle circle
  • Computers & Internet
