20 Most Recent Dell UltraSharp 2000FP 20.1" Flat Panel LCD Monitor Questions & Answers
looks like problem in internals cards from my point of view i recommend you to buy a new one !
Dell UltraSharp... • Answered on Oct 15, 2013
I just fixed my Dell 2000FP LCD monitor and right now using it.
The solution is very simple and easy. Do it your self if you are comfortable soldering.
Resolder the 2 transformer legs ( 9 legs each transformer), 2 oranger capitors, 2 small green capitors, 2 inductors coil legs.
Use at least 45 watts soldering iron with a pointed tip. Be careful.
Roan
Dell UltraSharp... • Answered on Jan 05, 2012
This is a backlight problem. The picture is there but there is no light from behind the LCD screen. It could be due to faulty capacitors, which are easy to replace. It could be a faulty Inverter transformer, which is harder to fix but he backlight controller board can usually be replaced at a reasonable price. If you have soldering experience you may be able to replace the faulty capacitors - look for capacitors with bulging tops.
Repalcing the inverter board in a job for someone with electronics experience. You can buy a universal inverter board for about £15 to £20 from e-bay.
20 inch monitors can be bought for about £100 to £150 so you need to decide whether it is economical to repair.
Dell UltraSharp... • Answered on Feb 18, 2011
It is not so difficult to repare if you have scills to open the monitor and scills in un-soldering/soldering electronic components, than yes it is worth it, but if you go to a shop they have a tendency to sell you another monitor since the price they charge to repare the powersupply is about the same as a new monitor
well. you don't lose anything when that happens.
It sounds like the powersupply of the monitor might be going out, it might be cheap to repair, possibly a capacitor in the output area or two is bad and would need to be replaced.
Those are generally 5 to 20volt capacitors with 150 to 1000 uf values.
Dell UltraSharp... • Answered on Apr 17, 2010
Disconnect the Monitor from the PC, and keep it still powered on. If it displays horizontal lines, it means monitor has gone bad. If not then go to PC's BIOS, if it shows lines there then your graphics card/chipset has gone bad. Else its your graphics driver/operating system. Can try an update/reinstallation of driver.
Regards,
Shrey
Dell UltraSharp... • Answered on Oct 10, 2009
You have bad El-condensator on secondary side of power supply.
Dell UltraSharp... • Answered on Oct 06, 2009
This is a common problem, I don't think the LCD per say is bad. The backlight tube may be bad or the power inverter that powers it may be bad. GO to support.dell.com and search for these parts, get them both and replace them both. It is tricky as you must dissasemble your laptop lid panel.
Dell UltraSharp... • Answered on Jun 03, 2009
The monitor is going bad. Either going to be a bad screen or a bad inverter. Also Since you tried it on another computer and its still giving you the same symptoms, you know the computers are fine. To be sure, try another monitor on your computer and if you get video on the new monitor then thats another way of verifying that the dell monitor is bad.
Dell UltraSharp... • Answered on May 16, 2009
Here is one in an ebay store
and here is a google shopping search with several options.
Dell UltraSharp... • Answered on Aug 11, 2008
you have the vertical circuit "closed" you have to repair it checking
transistors and capacitors . if you can  it this work may be at low cost - few dollars
Dell UltraSharp... • Answered on Mar 21, 2008
built in windows on screen magnifying glass: https://support.microsoft.com/en-us/help/11542/windows-use-magnifier a more advanced version https://technet.microsoft.com/en-us/sysinternals/zoomit.aspx
Dell UltraSharp... • Answered on Aug 22, 2016
Try to use another power cable, or another power socket . If won't on, maybe you have problem with the monitor. Have you pressed the power switch?
Dell UltraSharp... • Answered on Jun 13, 2015
You need to remove the standard windows monitor driver in the device manager and reinstall the monitor driver. Search in google and download the driver and install it. Good hunting.
Dell UltraSharp... • Answered on Dec 07, 2014
Dell UltraSharp 2000FP 20.1" Flat Panel LCD Monitor Logo
20 questions posted
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
UltraSharp Dell
  • UltraSharp Dell
Most Popular Question
monitor dell 2000 flat screen 20 1
  • Computers & Internet
