20 Most Recent Dell UltraScan P990 19" CRT Monitor Questions & Answers
Try this:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_faq?c=us&l=en&s=gen
Dell UltraScan... | Answered on Dec 16, 2009
1. Speakers working volteage 6V , 9V, 12V. you do onething give me the 5V ,from system SMPS ( black & red colour wires ) you should maintain the polarites. black wire is negative, red wire is positive.its working fine , then give me the 12V from SMPS. ( black & yellow wires )
if u dont maind u have any electronics knowledge. otherwise u should used adopter. there is any problem please give me the mail
Dell UltraScan... | Answered on Oct 13, 2008
i had the same problem within a couple of days the monitor will stop working and it will start to beep....
Dell UltraScan... | Answered on Feb 27, 2008
if you have your os as microsoft then go to help and support centre and type in " burning cd with audio files " make sure the internet is turned on as microsoft will search related quiries in it records and will surely give you the appropiate answer for this HAPPY BURNING!!!!!!!!!!!!!!
Dell Computers &... | Answered on Mar 31, 2020
why not ask at dell.com (sure the endless laughter and taunts) ;-)
is this a laptop, and is useless now. totally.
but the battery is bad, remove the big battery it is shorted now.
then the coin cell battery went dead 2 decades go.
and now the HDD is bad.
why in the world waste or worse money on this junk
far far better fish in the sea, far newer, and cheap. used.
this lappy has CCFL back lamps that went bad long ago.
no fix for that under $100.
this PC has no value at all, why mess with this pig.
Dell Computers &... | Answered on Mar 20, 2020
go to myxer.com and find a song you want then there should be a button that says download for iphone. You will then download the file. Once downloaded you click and drag that file onto iTunes on the top left where is says music, movies, ect. it will then make a ring tone category you can now sync you phone and the ring tone should me there :)
Dell Computers &... | Answered on Mar 07, 2020
Pull the plug from the wall. That will turn it off!
Dell Computers &... | Answered on Mar 01, 2020
You have to go into the BIOS and reset everything, including the Boot Sequence and which drive to access the operating system.
Battery in the right way around?
Dell Computers &... | Answered on Feb 25, 2020
See the videos. CR2032 Lithium battery. They are all the same. Very easy job, but unlikely to be what your no boot situation is about.
https://www.google.com/search?q=cmos+battery+replacement%2C+dell+490
Dell Computers &... | Answered on Feb 24, 2020
You can download/ install Media Player Classic
Download the latest version of Media Player Classic (K-Lite Codec) FOR FREE
It is a small but a very fine Media Player which also installs all the required CODEC and you can play all audio - video files.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Dell Computers &... | Answered on Feb 17, 2020
no model stated, at all, must be old no? laptop from 2000 to now.
vast ,please tell what PC this is, REAL models matter.
https://en.wikipedia.org/wiki/Dell_Inspiron_laptops
AC power pack removed.
step 1, remove the old huge battery first and with AC pack back and connected , run the PC now.? on AC power only?
yes, good. battery is bad
if not the AC pack can be bad, a cheap fix that.
No cure,? the RTC coin cell battery deep inside is bad.
yes cured, great, no cure, then remove RAM sticks and reseat them.
cured now?
the beep means hard fault, there are up to 20 things inside that can fail.
the 20 steps are here.
https://www.pcdied.com/intel-magic/Powerbrain-LT/power-dead1.html#The_strip_down_test_is_next
Dell Computers &... | Answered on Feb 16, 2020
Hello Bill.
12 year old PC laptop.
tell what is locked most PC have 2 to 7 or more locks, I can not see your screen to even begin to guess what you see.
it is an old laptop. tell how far you get turned on,?
what OS do you run,, windows? and is it w10?
it came with VISTA, so still old old VISTA.
you power it an and get Dell splash screen
then it stalls, or show asking for BIOS Admin Password.
or does not ask then goes to wndows login screee
where does the PC LOCK> I can not guess, screens. ok>?
Dell Computers &... | Answered on Feb 14, 2020
Windows 10 right>? no OS told. but is windows sure.
\my guess is a dead DRIVE, if the drive does not PnP show up
that means A: it has no power, or B: the PnP chip inside is dead..
C : cables bad..
PnP means plug and play, and is a chip in all things that tell the PC WHO AM I, Identification even USB devices, same and all cards and RAM and yes HDD, and DVD drives
does the tray button work, eject? if not it has no power.(or is brain dead)
if you reverse the cables on the 2 drives, does the problem follow the
the DRIVE or cable ports.?
if follows the cables, . replace the cables, SATA..
the 3847 is only 6 years old , are any drives older?
that is it, besides testing any Drive on 2nd PC to gain proof, easy./
Dell Computers &... | Answered on Feb 13, 2020
You can try GT Recovery for Windows!
GT Recovery for Windows is a professional data recovery for Android phone or tablet. It can restore deleted photos,videos,audios,documents from Android SD card and internal memory. Whenever you lost important pictures or deleted photos by accident, you can use it to scan and recover the images on your Android devices.
Here are the steps to recover deleted data on Samsung Galaxy S4.
With this way you can recover deleted data on any brands of Android device such as Samsung, HTC, Huawei, Sony, Motorola, Lenovo, LG, Sharp, etc.
Download link:http://www.gtrecovery.net/
Dell Computers &... | Answered on Feb 06, 2020
Dell laptops don’t come with a bios password by default. You or someone else who have used this laptop in the past, must’ve set that up. There is no factory default password.
Dell Computers &... | Answered on Jan 18, 2020
Dell UltraScan P990 19" CRT Monitor Logo
5 questions posted
Ekse
Thomas F. Schneider
Joel Rodriguez
Joel Rodriguez
View Most Popular
UltraScan Dell
  • UltraScan Dell
Most Popular Question
dell ultrascan p990 19in crt getting
  • Computers & Internet
