20 Most Recent Dell E151FPp 15" Flat Panel LCD Monitor Questions & Answers
The resolution is set too high for your monitor and you have to throttle it down to a lower number.
Dell E151FPp 15"... | Answered on Apr 09, 2017
Can you restore all settings from the menu?
Dell E151FPp 15"... | Answered on Oct 26, 2011
The problem may be a loose connection. When I turn on my monitor, the green light blinks and a flickering white screen appears for a brief second every time. There must be a loose connection on the power board which may be causing this. The easiest solution is to tap at the back of the monitor. This will reconnect the loose end and the monitor will work fine until it gets disconnected again. I will open my monitor soon to find the real problem. But it will take some time to find it.
Dell E151FPp 15"... | Answered on Dec 09, 2010
Look for cold solder joints in the power supply board (at the main AC inlet and in the DC supply and inverter sections), see example of faied DELL monitors here: http://s807.photobucket.com/home/budm/allalbums
Replacement board: http://www.lcdrepair.us
Dell E151FPp 15"... | Answered on Aug 30, 2010
mi monitos es diferente a mi pc puedo conectarlo
Dell E151FPp 15"... | Answered on May 22, 2010
The 32bit color has nothing to do with monitor driver, that the video card driver issue, it sounds like you do not have correct driver for you video card.
Dell E151FPp 15"... | Answered on May 20, 2010
three things i find to cause this,
one, the power supply is bad,
two, the power connector is lose or not push in
three, the heat sink on the processor has come off. This will cause the cpu to over heat and self shut off.
to test the power supply, pull the connector off the mother board and short the green wire to any black wire with a paper clip, this will switch on the power and see if it stays on.
if you need to replace it, you cannot use a regular atx power supply. E machines have a different pin out.
Dell E151FPp 15"... | Answered on Aug 12, 2009
sounds like a video card problem in your pc. If you are using the onboard video output on your motherboard, you probably need a new one. If you are using a card that has been added to the board in a slot, try your onboard output (looks the same)
Dell E151FPp 15"... | Answered on Jun 15, 2009
Someone has probably changed the brightness settings. Increase the brightness and see if this resolves the issue. If it does not then I would assume that the monitor's backlight is a toast and you may have to install a new backlight.
Dell E151FPp 15"... | Answered on Feb 15, 2009
An out of date BIOS can cause this error code. From Dell Drivers and Downloads website download and Install the latest BIOS. If prompts you to update the previous version, you must first update the same and then flash to the latest version of BIOS.
Dell Computers &... | Answered Yesterday
It alway zs helps to know the model number. Witht that information, you should be able to find the specifications at the Dell support site. It would simply tell you in a specs sheet. I guess you could download HWinfo, a handy freeware program and check informaiton about components there. There is of course the option to download the user manual.
Dell Computers &... | Answered 2 days ago
This may be due to a bad cable between LCD screen and laptop. That of course would require replacement of that video cable. There are some other things you can try before that: q) update the BIOS 3) go to the Dell site and update the drivers 3) ho/ Buld the D key down during powerup to initialte a screen test (if it fails, you may have a motherboard problem) 4) you can try a re-imaging drive recovery operation. Gur the problem may require replacing the wiring harness betwen the laptop and the LCD screen. https://www.blogarama.com/technology-blogs/1295362-dell-technical-blog-latest-news/23538451-fix-inspiron-error-code-2000-0321
Possibly incorrect battery installation
Dell Computers &... | Answered on Nov 19, 2020
It would apear you have either an optical drive issue or system board failure.
If you changed anything before this issue, change it back.
Dell Computers &... | Answered on Nov 18, 2020
Hard drive is failing or has failed.
Replace the hard drive.
Dell Computers &... | Answered on Nov 13, 2020
Dell E151FPp 15" Flat Panel LCD Monitor Logo
21 questions posted
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
View Most Popular
  • Dell Computers & Internet
Most Popular Question
screen lost its brightness
  • Computers & Internet
