20 Most Recent
Jeep 2004 Grand Cherokee Laredo Questions & Answers
Why isn't A/C working?
The AC unit on vehicles will not work if AC is not properly charged. Clutch will not engage. There is internal device that will not let the a/c start if under charged. System has to be evacuated and have fresh freon added to full capacity. Use leak stop and lubricants with the new AC freon.
Check all fuses/ relays for AC unit.
Use a freon gas sniffer/die tool to check for leaks.
Error code P1763
http://www.jeepforum.com/forum/f13/p1763-code-174927/ forinstance this guy needs to replace both the sensor and the solenoid and perhaps mod it like the dodge guys have done its a bad governor pressure sensorlooking here you'll find the issue and checking out this error its common to dodge also there is also other mods to the transmission to stop it happening http://answers.edmunds.com/question-I-1998-Dodge-Ram-1500-Codes-P1763-P1762-showing-Truck-hesitation-gear-77877.aspx{you need to paste this into the browser}but this is the erroryou replace it and clear the code
