20 Most Recent Dell M770 17 in.CRT Conventional Monitor Questions & Answers
Power ok but no display
check cable - try with a known good one Try with another monitor (it need not be CRT, can be LCD with the correct connector) Next try a different graphics card (known good) in your PC, or switch back to on-board, integrated graphics. If it still doesn't work, suspect your motherboard. I'm assuming you get the one beep from your system when you power up indicating it passed Power On Self Test, and hard disk activity from booting up. If not, the procedure will be different. 15.January.2015
1/15/2015 11:38:56 PM • Dell M770 17... • Answered on Jan 15, 2015
Led is flashing
the display resolution must have changed after playing a game or using some software so that's why the LED is blinking.Boot the PC in Safe mode & lower the resolution of your display
10/16/2013 8:10:20 AM • Dell M770 17... • Answered on Oct 16, 2013
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
1/29/2024 9:26:36 PM • Dell Computers &... • Answered on Jan 29, 2024
2answers
Dell Latitude won't connect to internet. Windows XP.
It is too old, plus XP is a virus magnet and has been unsupported by Microsoft for nearly 15 years. Mainstream support for Windows XP ended on April 14, 2009. Windows 7 and 8 have passed you by, Windows 10 is current and Windows 11 awaits. https://www.google.com/search?q=Dell+Latitude+won%27t+connect+to+internet.+Windows+XP ..
1/16/2024 8:34:33 PM • Dell Computers &... • Answered on Jan 16, 2024
Where can I get a replacement adapter cord for my Dell 3052 - 20" all in one model reg model W158?
Amazon, or if you only want the main lead, Walmart.
AC/DC Adapter For Dell Inspiron 20 Model 3052 20- ...
Amazon.ca https://www.amazon.ca > Adapter-Inspiron-20-3052-... AC/DC Adapter For Dell Inspiron 20 Model 3052 20-3052 W15B W15B002 All-in-One Desktop PC Power Supply Cord Cable PS Battery Charger Mains PSU : Amazon.ca: ... $26.27 · ‎ In stock ..
1/11/2024 6:55:07 AM • Dell Computers &... • Answered on Jan 11, 2024
My dell laptop i5 does not recognize the external ac source
I would try another power supply and plug that in.
1/5/2024 9:01:17 PM • Dell Computers &... • Answered on Jan 05, 2024
Where is the reset button on the dell inspiron 3052 tag c99f22
Try replacing the BIOS battery for access to the computer.
10/23/2023 4:58:31 AM • Dell Computers &... • Answered on Oct 23, 2023
Are there any other ways to bypass the log on screen on a dell inspiron 3052 so i can factory reset it
Windows can be accessed renaming two files. computingterror.blogspot.com/2014/03/hack-windows-7-login After that being done you should run the Support Assist OS Recovery from DELL dell.com/support/kbdoc/en-us/000177401/restore-your-system-using-dell-supportassist-os-recovery Windows 10 can renew itself, without Windows Setup on a USB medium.
10/23/2023 4:55:37 AM • Dell Computers &... • Answered on Oct 23, 2023
Alpha Lansing ACS400; Dell Inspiron 3020 Windows 11. PC won't recognize speakers. No sound.
Go here [9 Ways] How to Open Windows 11 Device Manager Quickly? - MiniTool Remove all device under sound video and game controllers, and audio in and out.. Then reboot your computer.
10/4/2023 10:39:39 PM • Dell Computers &... • Answered on Oct 04, 2023
I've got a dell inspiron 20 model 3052 series how do you reset it to factory settings or reset the password thought it was a monitor any help would be very greatfull!
Unfortunately, resetting a Dell Inspiron 20 model 3052 series to factory settings requires you to use a recovery disk or USB drive, as the system does not include a built-in resetting option. To reset your password, you will need to use a password or recovery disk. You can create a password or recovery disk using the Dell Support website.
9/2/2023 11:52:56 AM • Dell Computers &... • Answered on Sep 02, 2023
Dell Precision M4600 will not go past POST, Stops at Preparing to enter setup
If your Dell Precision M4600 is getting stuck at the "Preparing to enter setup" stage during POST, you might want to try a few troubleshooting steps. 1. **Power Cycle:** Disconnect the laptop from the power source, remove the battery (if possible), and hold down the power button for about 15 seconds. Then, reconnect the battery and power source and try booting again. 2. **Reset BIOS:** You could try resetting the BIOS settings to their default values. To do this, look for a small button battery on the motherboard. Disconnect the laptop from power and remove the battery. Press and hold the power button for a few seconds to discharge any remaining power. Then, locate the battery, remove it for a minute or so, and put it back. This will reset the BIOS settings to default. 3. **Update BIOS:** If the issue persists, you might need to update the BIOS. Check the Dell support website for your laptop model and download the latest BIOS update. Follow the instructions to update the BIOS. 4. **Check Hardware:** If the issue is not resolved, it might be related to a hardware problem. Try removing and reseating components like RAM, hard drive, and any expansion cards. 5. **External Devices:** Disconnect all external devices (USB drives, external hard drives, printers, etc.) and try booting again. Sometimes, a faulty external device can cause boot issues. 6. **Diagnostic Lights:** Dell laptops often have diagnostic LED lights that provide information about hardware issues. Check the user manual for your laptop model to interpret these lights. If none of these steps resolve the issue, it might be worth seeking professional assistance or contacting Dell support for further guidance.
8/23/2023 8:49:51 AM • Dell Computers &... • Answered on Aug 23, 2023
Empowering technology windows xp
We recommend upgrading to another level of operating software, or perhaps windows 7 windows 8 is that they are available for more security and development update...We recommend upgrading to another level of operating software, or perhaps windows 7 windows 8 is that they are available for more security and development update ... windows 7 upgrade will soon be without ...
8/12/2023 6:02:40 PM • Dell Computers &... • Answered on Aug 12, 2023
Im trying to factory reset my dell inspiron 1100
Maybe this will help. https://www.dell.com/support/kbdoc/en-us/000192008/how-do-i-erase-data-from-my-hard-drive-or-mobile-device-before-trade-in
8/8/2023 8:57:40 PM • Dell Computers &... • Answered on Aug 08, 2023
Bios boot password on Dell Inspiron 7737?
This may help. https://www.dell.com/support/kbdoc/en-uk/000131024/how-to-clear-the-bios-password
8/4/2023 8:37:29 PM • Dell Computers &... • Answered on Aug 04, 2023
Dell laptop peeps 8 times when i press the power button
https://www.ifixit.com/Answers/View/368254/8+beeps+in+starting+windows
8/3/2023 5:31:30 PM • Dell Computers &... • Answered on Aug 03, 2023
How do you connect 3 monitors on an Optiplex 7010,Dell 7010 has 2 DP ports built in and 1 Vga port
To connect three monitors to a Dell Optiplex 7010, you can use the built-in DisplayPort (DP) ports and the VGA port. Here's how you can set it up:
  1. Check the available video ports: As you mentioned, the Dell Optiplex 7010 has two DisplayPort (DP) ports and one VGA port. Make sure all three monitors support at least one of these connection types.
  2. Connect the first monitor: Use a DisplayPort cable to connect the first monitor to one of the DP ports on the Optiplex 7010. Ensure that both ends of the cable are securely plugged in.
  3. Connect the second monitor: Connect the second monitor to the other DisplayPort (DP) port on the Optiplex 7010, using another DisplayPort cable.
  4. Connect the third monitor: Since the Optiplex 7010 has only two DP ports, you'll need to use the VGA port for the third monitor. Connect the third monitor to the VGA port using a VGA cable.
  5. Configure display settings: Once all three monitors are connected, you'll need to configure the display settings to extend the desktop across all monitors. Right-click on the desktop and select "Display settings" (Windows) or "System Preferences" -> "Displays" (macOS). From there, you should be able to set the arrangement and orientation of the displays.
Note: When using multiple monitors, it's important to consider the graphics capabilities of your computer. The Optiplex 7010 might have limitations on the maximum resolution and refresh rate it can support across multiple displays. Check the specifications of your specific Optiplex 7010 model to ensure it can handle three monitors simultaneously. If you encounter any issues or limitations, you may need to consider using additional hardware, such as a DisplayPort splitter or an external graphics card, to connect and support three monitors.
7/15/2023 1:23:39 PM • Dell Computers &... • Answered on Jul 15, 2023
Why can't I get my Pyle HDMIUSB50 microphone to work with my Dell PC?
In the Settings app, click Privacy & Security (in Windows 11) or Privacy (in Windows 10). Under App Permissions, click Microphone, and make sure Microphone access is turned on. In Windows 10, select Change, and then turn on Allow apps to access your microphone. Choose which apps have access to the microphone
7/13/2023 7:38:13 PM • Dell Computers &... • Answered on Jul 13, 2023
Dell M770 17 in.CRT Conventional Monitor Logo
7 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
power ok but no display
  • Computers & Internet
