20 Most Recent Hansol 700 FS 17" LCD Monitor Questions & Answers
2answers
My Hansol 700FS monitor refuses
Most probable components that might need to be replaced include the fuse & rectifier diodes (or bridge rectifier). You better test the monitor after the replacement of the components using the serial light bulb technique. If there are still more burnt components, you will have to test power transistors & power regulators as they are the next most likely components to have been burnt.
11/24/2010 8:47:31 PM • Hansol 700 FS... • Answered on Nov 24, 2010
I have entered the power plug connected to the
If you open up he back and look at the circuit around the DC input jack, you should see a surface mounted fuse and may be a crowbar protection Diode. Please look for that and report back, picrues will help a lot.
Basic LCD monitor troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
11/24/2010 6:35:41 PM • Hansol 700 FS... • Answered on Nov 24, 2010
My hansol 700Fs silver just blacked out one day.
Try remove the video cable from the CPU, if there's a sign of anything(warning,etc), try it in another CPU, this should works.
And the problems is in Video Card from the CPU.Try replace this Video Card.
12/8/2009 11:32:02 AM • Hansol 700 FS... • Answered on Dec 08, 2009
0answers
0answers
2answers
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
3/27/2010 6:28:59 PM • Hansol Computers... • Answered on Mar 27, 2010
2answers
My computer froze while I was transfering files
In such cases the buttons do not work. Go to start->Control Panel->Display->Settings->Advanced->Monitor->Properties->Drivers. Here you will find an option of Uninstall drivers. Select it. and close all windows. Reboot the PC. Start->Control Panel->System->Hardware->Device Manager->Action->Scan for New HW. Windows will scan for new display and load its drivers. Your display would be alright.
12/12/2009 7:29:31 AM • Hansol Computers... • Answered on Dec 12, 2009
I got a hansol h711 monitor as a present but it
We carry the adapter you need, they run $16.95 plus $4.50 shipping.
Let me know at [email protected] if you are interested.
Buddy
Corporate Computer
www.ccl-la.com
7/15/2009 2:49:37 AM • Hansol Computers... • Answered on Jul 15, 2009
0answers
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered 10 hours ago
Upgrades software
If you want to upgrade your software for example your operating system. Your systems unit support only for windows 7, windows 8 and windows 8.1. You may visit this website to download the latest driver for your operating system installed. http://support.lenovo.com/en_PH/downloads/detail.page?DocID=DS035527
4/22/2024 1:20:20 PM • Computers &... • Answered 2 days ago
2answers
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
4/21/2024 5:41:42 AM • Computers &... • Answered 3 days ago
2answers
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
4/21/2024 4:20:47 AM • Computers &... • Answered 3 days ago
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered on Apr 18, 2024
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered on Apr 17, 2024
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 4:37:13 PM • Computers &... • Answered on Apr 16, 2024
How to get free backlinks?
YouTube Backlink Generator https://ovdss.com/apps/youtube-backlink-generator
4/13/2024 3:06:42 PM • Computers &... • Answered on Apr 13, 2024
Hansol 700 FS 17" LCD Monitor Logo
4 questions posted
Top Hansol Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Hansol Computers & Internet
Most Popular Question
entered power plug connected
  • Computers & Internet
