20 Most Recent Jeep 2002 Grand Cherokee Laredo 4WD Questions & Answers
2002 Grand Jeep Cherokee Laredo. Cylinder 2 and 6 misfire on it.
Did you clear the codes? Swap coil packs from 2 and 6 to 1 and 3. See if the code moves. If they don't suspect faulty or incorrectly gapped plugs.
12/3/2022 10:55:25 PM • Jeep 2002 Grand... • Answered on Dec 03, 2022
No firing by spark plug wire for 2002 jeep cherokee laredo 6 cyl. 4.000
The ECU or some engine sensors have failed. Run a diagnostic test to find out which part is causing the problem.
9/14/2017 9:19:13 PM • Jeep 2002 Grand... • Answered on Sep 14, 2017
Jeep grand cherokee 2002 check gages light came on now won;t start
Battery draining indicates a possible ground problem. Check all grounding for battery, and check other cables for loose connections. Battery connection may be loose.
9/9/2016 9:55:08 PM • Jeep 2002 Grand... • Answered on Sep 09, 2016
What is the timing settings
If thats all you replaced, the timing hasn't changed by doing that. You may have a very loose timing chain and worn cam and crank gears that have allowed the timing to slip
9/9/2016 8:31:11 AM • Jeep 2002 Grand... • Answered on Sep 09, 2016
Location on fuse boxes on 2002 jeep grand cherokee
if you do not have your vehicle owners manual please try this webiste,http://www.wjjeeps.com/fuses.htm.
7/16/2016 12:48:53 AM • Jeep 2002 Grand... • Answered on Jul 16, 2016
2answers
02 sensor for jeep 2002 jeep hrand cherokee
There are number of sensors in 2002 Cherokee, you need to specify which one, or explain how the vehicle behave then I can try to see which sensor got some problems
3/20/2016 11:06:56 PM • Jeep 2002 Grand... • Answered on Mar 20, 2016
Air fuel ration sensor
it is in the exhaust pipe /manifold in bank 1 before the cat converter
9/18/2015 9:19:23 AM • Jeep 2002 Grand... • Answered on Sep 18, 2015
P0138 location air fuel ratio
code p 0138 refers to heated oxygen sensor (HO2S) 2 bank 1--high voltage ===causes --wiring short to positive --HO2S--ECM replace the sensor
9/18/2015 9:18:17 AM • Jeep 2002 Grand... • Answered on Sep 18, 2015
Jeep no heat blower works gurgling sounds from dash
yes your heater core is plugged
8/14/2015 7:42:11 PM • Jeep 2002 Grand... • Answered on Aug 14, 2015
Check battery light comes on when driving lights go dim 02 jeep grand cherokee
Most likely the alternator is failing to supply enough power to battery. Check battery terminals and wires are clean and tight, check wiring to lights and alternator for signs of heat. Check voltage at battery with multimeter with engine running and a high idle. Voltage should be at least 13.5 volts with lights on or off.
1/9/2015 10:49:14 PM • Jeep 2002 Grand... • Answered on Jan 09, 2015
2answers
Noise 2002 Grand cherokee 4.0 Liter good oil Pressure don't smoke idle good got a loud knocking noise took off valve cover all the rockers pump oil all the rockers are good
sounds like a rod knock, how many miles? I would switch over to Castrol 20-50,, all I have run in my cars ( 1994 and 1995 Jeep Grands) and both cars have over 200K on them problem free..
1/2/2015 2:37:19 PM • Jeep 2002 Grand... • Answered on Jan 02, 2015
My brakes lights only works when the head lights are turned off.
check the bulbs to make sure that the light element isn't blown in them if the bulbs are all good then you might try this video https://www.youtube.com/watch?v=HZtcqIwipXs
12/24/2014 2:37:03 PM • Jeep 2002 Grand... • Answered on Dec 24, 2014
How can i tell the specific issue
Pull the sump off and inspect the con rods for movement.
9/12/2014 6:44:10 AM • Jeep 2002 Grand... • Answered on Sep 12, 2014
Car won't turn on after power steering pump installation?
Did you replace all the wires on the positive side? Also the negative cable bolts to where on the frame? Check those
8/2/2014 12:42:22 AM • Jeep 2002 Grand... • Answered on Aug 02, 2014
Hyvac removal on 2002 jeep grand cherokee
this is covered 100% ;in the fsm or at alldata.com and for free here. RTM http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service posted 100s of times.
5/28/2014 9:16:30 PM • Jeep 2002 Grand... • Answered on May 28, 2014
Jeep 2002 Grand Cherokee Laredo 4WD Logo
52 questions posted
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Ben Slimene Aymen
Ben Slimene Aymen
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jeep Car Audio & Video
Most Popular Question
timing settings
  • Car Audio & Video
