20 Most Recent Hansol Multitech 920p 19" CRT Monitor Questions & Answers
DO U KNOW WHAT IS REGULATION?
AT FIRST KNOW WHAT IS REGULATION, THEN ASK Q.
Hansol Multitech... | Answered on Jul 06, 2010
Hi, constant high pitched whine from most monitors have something to do with the horizontal frequency which is partly affected by the screen resolution as set in your computer display properties. Try lowering down your resolution or go into safe mode. if the whine disappears, it may be that the monitor is not fully capable of displaying too high a resolution. If the whine continues even at safe mode or lower screen res, then you would need to consult a qualified technician to check for defective components in the horizontal circuitry of your monitor. I wouldn't recommend that you take look due to the presence of extremely high voltage in that area. Hope this be of some help. pls post again how things turn up. kind regards.
Hansol Multitech... | Answered on Apr 24, 2009
To my knowledge, it is not the zoom that has to be adjusted but rather the horizontal width, zoom would expand all (to, bottom & both sides) whereas your only concern are the two sides.
Should the horizontal width not fully expand, then there is an internal problem with the horizontal deflection circuitry which could either be the yoke, a capacitor or shunt diodes. In certain instances, a below normal voltage at the mains or the internal power supply could also cause this.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Hansol Multitech... | Answered on May 21, 2008
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
Hansol Computers... | Answered on Mar 27, 2010
In such cases the buttons do not work. Go to start->Control Panel->Display->Settings->Advanced->Monitor->Properties->Drivers. Here you will find an option of Uninstall drivers. Select it. and close all windows. Reboot the PC. Start->Control Panel->System->Hardware->Device Manager->Action->Scan for New HW. Windows will scan for new display and load its drivers. Your display would be alright.
Hansol Computers... | Answered on Dec 12, 2009
We carry the adapter you need, they run $16.95 plus $4.50 shipping.
Let me know at [email protected] if you are interested.
Buddy
Corporate Computer
www.ccl-la.com
Hansol Computers... | Answered on Jul 15, 2009
contact the service provider
Computers &... | Answered 2 hours ago
Delete my Facebook account
Computers &... | Answered 3 hours ago
YOU DID NOT BUY FROM FIXYA SO GUESS YOU NEED TO GO TO THE SELLER
Computers &... | Answered 5 hours ago
CAT6 cables & jacks are better than CAT5E.
CAT5E cables & jacks are better than CAT5.
CAT5 cables & jacks are better than CAT3.
CAT3 cables have problems going faster than 10Mbit/second.
CAT5 cables support 100Mbit/second, and seem to work with 1000Mbit/second ("gigabit") devices.
Computers &... | Answered 8 hours ago
IF they are new, get a replacement, the wires in those are very small and subject to breaking. IF you cannot return them, get another set.
Computers &... | Answered 12 hours ago
You will need the sort code, account number and name of the account holder. If you are doing it online you need to go to your bank account details and look for payments to individuals or companies.
Computers &... | Answered 15 hours ago
Your fairy name is not a good name or your registering name is not a good one?
You can submit bugs here
Bug report
FAQ Here
FAQ
Computers &... | Answered 18 hours ago
Hansol Multitech 920p 19" CRT Monitor Logo
Popular Tags
4 questions posted
Top Hansol Computers & Internet Experts
Ekse
Gustavo Ortiz
Gustavo Ortiz
Robert Salgado
Robert Salgado
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Hansol Computers & Internet
Most Popular Question
screen whine
  • Computers & Internet
