20 Most Recent Jensen JPA600D - 600 Watts Digital Mono Amplifier Questions & Answers
2answers
Protect Light On Amp Being Weird
Could try switching right and left subs. If the problem moves to the other side pull the wiring and redo. Then if the wiring is ok check the sub.
12/18/2014 2:51:49 PM • Jensen JPA600D -... • Answered on Dec 18, 2014
I have a Jensen JMS7010 marine radio it has water in the face I want to take it apart and dry it out and try to save the radio but it want come apart how can I dry it out or take it apart?
hair dryer if just moisture if water [failed seal or damaged cover ] and need to unscrew ans pry apart --but if water most likely electric circuit damage
4/17/2023 12:21:15 PM • Jensen Car Audio... • Answered on Apr 17, 2023
Wiring diagram Jensen eoa 7p seven band speaker wires.
Your Jenson model as written only appears here on Fixya in your question. The Jenson modelling numbers don't follow what you wrote so your model number 'EOA 7P' is not valid. https://www.google.com/search?q=jensen+eoa+7p ..
4/11/2023 6:17:33 PM • Jensen Car Audio... • Answered on Apr 11, 2023
Jensen vm0312 is on, but tray will not flip up
It sounds like there may be an issue with the mechanical components of the DVD player, specifically with the tray. Here are some troubleshooting steps you can try:
  1. Check to see if the emergency eject feature is working. There should be a small hole on the front of the DVD player, and you can use a paperclip or a similarly sized object to push the button inside. This should manually eject the tray.
  2. Make sure that the DVD player is receiving power. Double-check all of the connections and fuses.
  3. Reset the DVD player by disconnecting the power for a few minutes, then reconnecting it and trying again.
  4. If none of the above steps work, it may be necessary to take the DVD player apart and check the mechanical components for damage or wear. However, this is not recommended unless you have experience with electronics repair.
If none of these steps resolve the issue, you may need to seek the assistance of a professional electronics repair technician.
2/24/2023 9:31:14 PM • Jensen Car Audio... • Answered on Feb 24, 2023
Can I use a 270 watt amp kit on a JENSEN 1000 WATT AMP
No, you cannot use a 270 watt amp kit on a 1000 watt amp. The wattage of the amp kit must be equal to or higher than the wattage of the amp it is being used for.
2/22/2023 7:13:10 PM • Jensen Car Audio... • Answered on Feb 22, 2023
I request a schmatic picture
This video may help you https://www.youtube.com/watch?v=VC89DgWJlYw
10/24/2022 1:16:31 PM • Jensen Car Audio... • Answered on Oct 24, 2022
What gauge power wire do I need for my 1200 watt Jensen octane amp
1200 Watts at 12volts is 100 Amps. At least 16mm on a short run.
10/15/2022 12:35:41 PM • Jensen Car Audio... • Answered on Oct 15, 2022
HOW TO SET TIME ON JACOB JENSEN ALARMCLOCK
7/21/2022 2:40:03 PM • Jensen Car Audio... • Answered on Jul 21, 2022
2answers
Jensen CAR1000 brake bypass?
Ground the parking brake wire
3/21/2022 11:29:34 AM • Jensen Car Audio... • Answered on Mar 21, 2022
2answers
I have a Jensen stereo cd/dvd player and when I load a cd or dvd into it constantly is loading and doesn't proceed
I used to own Jensen cd player for a while but I can't remember the solution of loop loading. Check Jensen cd-players manuals http://jensen.manymanuals.com/cd-players
11/21/2020 5:05:18 PM • Jensen Car Audio... • Answered on Nov 21, 2020
Jensen vx7022 head unit for car i was updating firmware and it got to the calibration screen and wont go any further no my unit doesn't work at all please help
There is always a chance that you "bricked" the unit with the update. IT happens. When you get to the cross hairs you are supposed to hold your finger in the middle till it asks for the next step. IF it wont go to this, then can you retry the whole process over again. If not you have bricked it and it has to be sent in for reflash
11/10/2020 5:02:31 PM • Jensen Car Audio... • Answered on Nov 10, 2020
2answers
Does the Jensen UV 10 stereo have internal fuses that can be replaced
In the back of the set you should find a small 'spade' type fuse, replace with Fuse: 15-amp, mini ATM type There is a fuse holder in on the yellow wire on the wiring harness, pull out the unit and replace fuse. User manual: http://www.jensenmobile.com/docs/common/UV10/UV10_OM.pdf Wiring diagram http://www.manualslib.com/manual/674477/Jensen-Uv10.html?page=4#manual Good luck.
8/6/2020 3:32:08 AM • Jensen Car Audio... • Answered on Aug 06, 2020
6answers
How to bypass jensen
I just purchased the VX7020 and went to Settings-Language-typed in 5,4,3,2,1,0 but the menu never came up. Any ideas?
5/20/2020 11:25:04 AM • Jensen Car Audio... • Answered on May 20, 2020
Jensen eqa-110 speaker wiring?
This info is on the bottom of it.
3/15/2020 12:19:31 PM • Jensen Car Audio... • Answered on Mar 15, 2020
Hi, I have a Jensen JCD 233u car radio, I've tried to connect the power on it but I fail, these only four power wires behind, ground, auto antena, memory and 12 volt positive wire, Please help how can I connect it ?
Ground - negative
12v positive - switchable positive (for example, on when ignition is on, usually connected to accessory side on ignition switch)
auto ant - connected to your electric antenna or to turn on external amplifier.
Memory - connected to always on positive (to keep all your stereo presets )
2/11/2020 1:18:39 PM • Jensen Car Audio... • Answered on Feb 11, 2020
Jensen JPA600D - 600 Watts Digital Mono Amplifier Logo
2 questions posted
Top Jensen Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Car Audio & Video
Most Popular Question
protect light amp being weird
  • Car Audio & Video
