20 Most Recent Sony SDM-HS95 19" LCD Monitor Questions & Answers
Either a loose/bad power cable or the backlight is failing.
Sony SDM-HS95... | Answered on Jan 30, 2018
Check for a loose power cord on the back of the monitor (quite common).
go to control panel and change the desktop background color
Sony SDM-HS95... | Answered on Apr 24, 2017
You are precisely right. This happens in Sony models. Have expirienced a lot of this problems relating this issue and all of them have been on Sony and Viewsonic LCD 19" and 22".
Sony SDM-HS95... | Answered on Apr 19, 2012
Click on the link below and download the manual to know how to change settings of your monitor
Monitor Settings Manual
Regards,
Shawn
Sony SDM-HS95... | Answered on Feb 03, 2011
You need to look inside your pc and check and see if the video card is plugged in tight. Sometimes if it is loose, and it isnt connected, and causes the monitor to not show any picture, but still has power.
Sony SDM-HS95... | Answered on Apr 03, 2009
set the display properties to clone mode
Sony SDM-HS95... | Answered on Nov 02, 2008
The push-button activates a small motor that turns a small rubber belt/ band that opens the cassette door. Since it's not been used for 10 yrs, I would say these belts would have deteriorated and broken. you will need to replace them. the best bet is to open it up and check. if its the case, you should be able to source the belts on ebay.
Sony Computers &... | Answered on Dec 03, 2019
this is easy, that OUT OF range means
the PC sending video is sending and illegall higher resolution
than the projector supports (or even less, on this old junk)
the manual on that old projector is clear on that. max.
SONY VPL-EX4 2007, 13 years old now.
and back then projectors STINK !
your manual shows this, and stinks.
what stinks worse is no matrix of legal H./V resolutions shown in the manual. (shows only 1)
so set the PC to 1400 x 1050 and do not use others . ok.
and 60Hz, are you in USA? not stated country.
Sony Computers &... | Answered on Nov 28, 2019
no OS stated, W10?
the drivers for your camera/mic are wrong, reload them from SONY..com
Looks like you are having a bad LCD screen, This could be due to drop damage. Cracks can be so tiny and may not be visible immediately. I would take it to a technician and get a screen replacement.
Sony Computers &... | Answered on Nov 27, 2019
You probably need more ram memory. Also try playing a video in your dvd player. If it plays slow and choppy you definitely need more ram memory.
If you are trying to play a video from a website (streaming) then three things can affect how smooth it plays.
1) Memory - your ram memory might be low
2) The website might be experience heavy traffic from many users.
3) The Line Speed of your internet connection from your service provider might be slow. For example: AT&T sells about 3 or 4 different packages and each one increases the line speed for uploading or downloading. If you buy the low end package the line speed is very slow on uploading and downloading or streaming. It's ok for just surfing, but nothing else.
Sony Computers &... | Answered on Nov 08, 2019
1st leave the battery out,
then power only with AC power pack
push power for 10seconds and releases.
the batteries are bad, as more are, in the wild. most.
Sony Computers &... | Answered on Sep 12, 2019
all things can be repair,
only price to do so matters.
one mans garbage is others treasure.
can't speak for you ever.
but in my hands yes, garbage.
spend hard cash on newer more supported products.
2010 or newer is good rule.
Sony Computers &... | Answered on Aug 31, 2019
Sony SDM-HS95 19" LCD Monitor Logo
15 questions posted
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SDM Sony
  • SDM Sony
Most Popular Question
suddenly get information box stating
  • Computers & Internet
