20 Most Recent Hyundai ImageQuest L70N 17" LCD Monitor Questions & Answers
hyundai will not repair this however a electronic service center aka tv repair may. I can do it as most likely is it several capacitors that have blown. Hyundai is also a little picky to open they are assembled very well actually compared to other monitors (they are difficult to open up) let me know what you would liek to do.
Hyundai... • Answered on Dec 05, 2013
You need new LCD panel, not worth it.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Hyundai... • Answered on Oct 22, 2011
If you restart in safe mode, you need to go to the display settings, and choose a resolution that will work. When you restart back into normal mode, this setting should be retained, and you will be back to normal.
Hyundai... • Answered on Aug 04, 2011
Check the caps first.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Hyundai... • Answered on Dec 13, 2010
Tear it apart and inspect the power supply and inverter circuit for bulging capacitors - they should have a flat tops. Replace the caps with identical values.
Hyundai... • Answered on Dec 08, 2010
That is a problem with the memory array in the monitor. If it is under warranty, don't even mess with it. Take it in. Otherwise open it up and exercise all the connectors on the logic board inside. That works about 30% of the time. If that does not fix it, then it is terminal. They are so cheap now that it doesn't even pay to try to get the repair parts. They will cost more than a new one.
Hyundai... • Answered on Nov 18, 2010
Can you try this monitor with another PC or this PC with another monitor? We need to find where you lose your signal at first before going further.
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
Hyundai... • Answered on Aug 31, 2010
This means that the monitor is not getting a signal from the computer. The problem could be the video or graphics card or it could be the monitor itself.
Try to connect the monitor into a known working CPU. If the monitor works, then you need to check your video card.Try to pull out the card and clean it using a DRY clean cloth. And then re-seat the card to the slot. If nothing happen, insert the card into an available video slot. or try different computer. If same problem occur, contact the manufacturer.
NOW, if the problem is the monitor, check the cable, try to use different video cable. If same problem occur, then it should be checked by a technician.
Thank you and good luck!
Hyundai... • Answered on Jun 28, 2010
Here is the service manuals: http://elektrotanya.com/?q=showresult&megnev=Hyundai&megnev2=l70n&kategoria=&kat2=all
Start checking the caps in the power supply, look for leaking/bulging tops, check voltages, etc.
Hyundai... • Answered on May 21, 2010
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Hyundai... • Answered on May 15, 2010
You usually do not need a disk to install a monitor, most of them are plug and play capable. If your getting an image that is blurry and out of perspective you may need to change your display size " standard 17 inch is 1280x1024 " If your on XP you can right click on the empty desktop and go to properties, Under the settings tab you will find options for screen resolutions. If your on Vista or 7 you right click on empty desktop space and go go screen resolution, There again you will easily find your settings for your screen resolution. Click apply and then click OK. If your still encountering problems such as no image at all you may have a problem with the monitor.
Hyundai... • Answered on May 09, 2010
http://driverscollection.com/?file_cid=24622933713hBuWizS5I1EwOBkI
Hyundai... • Answered on Dec 26, 2009
The flashing power light indicates a short in the power supply. This is a common failure point of LCD monitors2.gif after a few years of use. The heat build up in the monitor case causes parts called capacitors to blow leading to the power supply short. If you can solder you should be able to do the repair. Go to our web site at:
www.ccl-la.com/badcaps.htm We have pictures of what to look for. Now take the back off of your monitor and replace all of the caps that look like the pictures and you should be back going again. Be sure to use high temp parts, they will be marked 105c. The values you will need to get will be marked on the sides of the bad ones such as 220uf, 470uf or 1000uf. When you insert the new ones be sure to put the polarity stripe going the same direction as the old one comes out. If you have any questions just let me know. If you don't want to do the repair yourself we do offer a repair service for $30 + return shipping2.gif.
We also have a free chat available to talk to our tech 1 on 1
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Hyundai... • Answered on Nov 04, 2009
The blinking power light is a sure sign of a power supply failure. The heat buildup in the case causes parts called capacitors to blow and short out the power supply making the power light blink. If you can solder then you should be able to do the repair yourself. Go to our web site at:
www.ccl-la.com/badcaps.htm we have pictures of what blown capacitors look like. Now open up your monitor and look at the power supply. Replace all of the caps that look like the pictures and you should have a working monitor again. The replacement caps will need to be high temp which is marked 105c. The values that you need to get will be marked on the sides of the bad caps you take out such as 220uf, 470uf or 1000uf plus a voltage rating. The caps can be ordered from several places on the internet or we can supply them for you. Do not use caps from Radio Shack they are not rated for this type of use and will blow out in a few weeks of use. When you replace the bad ones be sure to insert them with the polarity stripe on the side going the same direction as the old ones come out. If you have any questions just ask. If you don't want to do the repair yourself we do offer a repair service for $30 + return shipping.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Hyundai... • Answered on Oct 25, 2009
CHECK CABLE CONNECTION TO PC...TIGHTEN IF NECESSARY...IF THAT DONT WORK TRY A SEC MONITOR IF CLEAR U HAVE A BAD MONITOR...IF BAD PIC..THEN U HAVE A BAD VIDEO CARD ON PC
Hyundai... • Answered on Aug 31, 2009
I have downloaded the manual from Hyundai website en_man_monitor_lseries_l52s.zip
Hyundai... • Answered on Jun 19, 2009
Hyundai ImageQuest L70N 17" LCD Monitor Logo
34 questions posted
Top Hyundai Computers & Internet Experts
Marvin
Marvin
ADMIN Canada
ADMIN Canada
STEVE
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ImageQuest Hyundai
  • ImageQuest Hyundai
Most Popular Question
hyundai l70n monitor periodically
  • Computers & Internet
