20 Most Recent Sony 2003 2004 03 04 Infiniti G35 Bose Am Fm Radio 6cd Changer Cassette Questions & Answers
If the rear speakers are fine, perhaps I can narrow this down. Fuses must be OK. Steering wheel audio controls connect to the audio unit which has a preamp function. The W/BK outputs connect to the left front inputs of the Bose speaker amplifier; the GRN/RED outputs connect to the right front inputs. Your ear test confirms the front door speakers are not working, therefore there is no front door output from the amplifier. The amplifier stages for the front doors may not be working or no front door amplifier input is being received from the audio unit. The fader and balance controls do not show on the diagram so must be on the front panel. They could be defective. There is a remote possibility of broken/disconnected wires
Sony 2003 2004... | Answered on Sep 18, 2012
Found it on the Sony support page.
Sony Car Audio &... | Answered on Mar 28, 2020
Request the wiring diagram directly from Sony.
Sony Car Audio &... | Answered on Oct 28, 2019
GO INTO THE MENU AND FIND THE AUDIO CONTROL FEATURE AND AND DO THE ADDJUSTMENT
Sony Car Audio &... | Answered on Oct 07, 2019
Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black
Sony Car Audio &... | Answered on Jun 09, 2019
No longer listed for sale as it is old. $40 used.
https://picclick.com/Sony-Marine-Stereo-Cd-Receiver-Deck-Cdx-M501P-183497958733.html
look at Jenson Marine instead. I have one on a Boston Whaler.
https://www.jensenmarinedirect.com/
Sony Car Audio &... | Answered on May 12, 2019
+ to battery, - to ground metal in the car location where you're installing and rem to blue on back of radio.
Sony Car Audio &... | Answered on Apr 16, 2019
I'm pretty sure it means that you have to much mucis downloaded
Sony Car Audio &... | Answered on Apr 04, 2019
If it ain't turn on at all check your fuse box. It could he a fuse under hood in car under dash. If the fuse is good then pull the radio out. Do a smell test on it. If you don't smell anything suspicous then check your red yellow and ground wire. Yellow being your switched 12v which turns off and on with ignition. Check red wire also. Also ground wire is very important.if none of those work it will need to be replaced. Check fuses carefully. A blown fuse can sometimes be easily missed
Sony Car Audio &... | Answered on Apr 02, 2019
Sony 2003 2004 03 04 Infiniti G35 Bose Am Fm Radio 6cd Changer Cassette Logo
4 questions posted
Top Sony Car Audio & Video Experts
Larry Stiles
Larry Stiles
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Car Audio & Video
Most Popular Question
04 infiniti sedan w factory bose front
  • Car Audio & Video
