20 Most Recent Sony CPD E500 (White) 21" CRT Monitor Questions & Answers
Put the case back. CRT has high voltages that can kill you! Take it to someone who knows what they are doing.
Sony CPD E500... • Answered on Jan 12, 2014
as u told ur monitor is excellent only... it is in good condition no problem will be there ... may be there is problem with the operating system just try reinstalling it... ur problem will be solved...
Sony CPD E500... • Answered on Mar 13, 2009
Monitor has gone to monitor heaven. time to do some shopping since repair not cost effective.
Sony CPD... • Answered on Apr 04, 2017
Go to the Optronics website and compare the pinouts and specifications. The easiest way to find out is to try it. However, you want to make sure the pinouts match.
Sony Computers &... • Answered on Feb 10, 2021
Unplug the keyboard from the mother board, re boot and try with a different keyboard. Probable liquid damage to the key switches.
Sony Computers &... • Answered on Jan 29, 2021
I have usually found it is better to format the hard drive and reload the operating system.
Sony Computers &... • Answered on Sep 30, 2020
the problem has to be from the display inverter board. The display inverter board is responsible from bringing display on the screen. Now since is no longer display, then it mean it has become defective.Get a philips screw driver, disassemble the unit in order to get to the display screen. You will see a kind of flex or wire connected to the screen. The board where the wire/flex is coming from into the screen is the display inverter board. The board is rectangular in shape.Remove the board, take it to an electronics parts store within your vicinity for exact replacement and the unit should display again.
Sony Computers &... • Answered on Aug 24, 2020
https://www.sony.com/electronics/support/televisions-projectors/kf-60we610/articles/S1Q0084 https://translate.google.com Le voyant de la lampe clignote Si l'?cran s'assombrit, que la couleur semble inhabituelle ou que le t?moin LAMP ? l'avant du t?l?viseur clignote, il est temps de remplacer la lampe par une nouvelle (non fournie). Utilisez uniquement un Sony XL-2100U ou XL-2100 de remplacement pour votre t?l?viseur. L'utilisation de toute autre lampe peut endommager votre t?l?viseur ? projection LCD. Contactez votre revendeur Sony pour une lampe de rechange. Cliquez ici pour t?l?charger des instructions ?tape par ?tape pour remplacer la lampe de votre t?l?viseur. Remarque: Avant de remplacer la lampe, mettez l'unit? principale hors tension. Attendez quelques minutes, puis d?branchez le cordon d'alimentation. (Le ventilateur de refroidissement continuera de souffler pendant environ deux minutes apr?s la mise hors tension.) Assurez-vous de laisser la lampe refroidir compl?tement avant de la retirer. La surface de la lampe reste extr?mement chaude pendant au moins 30 minutes apr?s la mise hors tension.
Sony Computers &... • Answered on May 03, 2020
Did you blow compressed air into laptop?. It is possible that something got disconnected or dirt stucked in powrr button
Sony Computers &... • Answered on Apr 22, 2020
Hi You can read more such errors and their solution from the given link. This blog will help to analyze the Lotus Notes problems and give you the easy approach to resolve them smartly. This will enhance your knowledge about IBM and the tips to fix them. Read more:- http://www.nsfsecurityremover.com/blogs/lotus-notes-error-messages/ Thanks
hi there might be...first go to my computer, then locate the dvd drive, right click that and then properties, then click the hardware tab at top then in the list locate dvd drive then at bottom right click on properties then click dvd region and then you should be able to change it....hope that helped
Sony Computers &... • Answered on Apr 17, 2020
You'll need a decoder from a program like cyber dvd or win dvd. Nero also has one and sonic too. If the drive came with a dvd player program install it. You can also find them through windows media player at microsoft's website but they will cost a few bucks. Search the internet for dvd player software you may find one for free. I hope this helps you. If you are like me you might have a program in your pile of software cds'.
Sony Computers &... • Answered on Mar 24, 2020
In Windows, open My Computer/Computer and explore/open the disk from it's drive.
Sony Computers &... • Answered on Mar 23, 2020
Sony CPD E500 (White) 21" CRT Monitor Logo
Popular Tags
4 questions posted
Top Sony Computers & Internet Experts
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
CPD Sony
  • CPD Sony
Most Popular Question
computer recognizes monitor power up
  • Computers & Internet
