20 Most Recent Hotpoint 4.87 cu. ft. / 138 liter Upright Freezer FZA50 Questions & Answers
Have you put a thermometer in the freezer? Leave it for half an hour to get a stable reading.
Hotpoint 4.87... | Answered on Feb 14, 2015
The defrost heater element has failed, it has created so much ice buildup on the cores air can not draw through the chanels in the cooling plate, should not be that expensive to repair.
Regards Russ
Dont forget to vote and if you need any more help, Email me at [email protected]
Hotpoint 4.87... | Answered on May 08, 2011
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for cold control and air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout.....
Hotpoint 4.87... | Answered on Aug 08, 2010
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Hotpoint 4.87... | Answered on Apr 10, 2010
well that light is the thermostat light and you should increase it for better performance.
Hotpoint 4.87... | Answered on Feb 20, 2010
The red light bis indicating that the temp is too high, if you can ,turn the thermostat to a colder setting, if this makes no difference, then you have a serious problem, you will have to call an engineer.
Plz rate this solution,
Thanks.
Hotpoint 4.87... | Answered on Dec 25, 2008
If this is a frost free unit as I received it posted you may have a problem in that it is not frost free. The cooling coil may be frozen over stopping air circulation. There would be a defrost timer located somewhere in back. Located the clutch head screw and turn it clockwise SLOWLY until you hear one audible click. That should put the system into the defrost mode. Wait about 30 minutes in which time the system should return to the cooling mode (usually 18-22 minutes). If it does not restart the compressor after that time turn the clutch head screw clockwise again and it should restart. If you had to turn the screw the second time it would indicate a bad defrost timer. In this case replace the timer.
Hotpoint 4.87... | Answered on Jun 17, 2008
try it on max setting. lint clogging up stuff in the back? needs defrosting? low on refrigerant (freon)? call repairman for that last one
Hotpoint 4.87... | Answered on Dec 04, 2007
A2 error Hotpoint fridge what is it mean I want to do
Hotpoint... | Answered on Jan 26, 2019
The buzzer will stop when the fridge reaches its correct temperature and a low temperature warning state no longer exists.
Hotpoint... | Answered on Jul 23, 2018
It is sensing low temperature because it hasn't reached temperature from ambient.
You should always let them stand for 24 hours.
Hotpoint... | Answered on Jun 18, 2018
clean the door rubbers and sides this sometimes fixes the problem as the seals are not closing properly and the fridge freezer thinks you have left the door open.
Hotpoint... | Answered on Feb 09, 2018
Hotpoint 4.87 cu. ft. / 138 liter Upright Freezer FZA50 Logo
20 questions posted
Top Hotpoint Freezers Experts
Andrew Taylor
Andrew Taylor
Thomas Perkins
Thomas Perkins
deton8 von Splosion
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
View Most Popular
Hotpoint Freezers
  • Hotpoint Freezers
Most Popular Question
high temp light
  • Freezers
