20 Most Recent Sony CCD-TRV238 Camcorder Questions & Answers
Sony hi8 video cam trying to record onto cd's through Sony dvd pl
Yellow connection for camcorder is your video output, the other one is for audio. If your DVD recorder does not have composite video inputs you will have to get an adapter to attach to your yellow wire and the other end of adapter will go to your recorder. OK?
9/1/2017 12:45:08 PM • Sony CCD-TRV238... • Answered on Sep 01, 2017
manual
Sony TRV128 analog camcorder displays
This will might seam odd to you ..but the fix in this case might be just a good smack on either side...cause it has a couple of connectors near the video head ..that makes problems on this mode..
Or like in the link I will provide under...some says to open the cover of the head...(remove the screws) and pull that connectors..-there are 2 of them )
here is the topic that talks about this issue
http://www.pechorin.com/m/2006/08/10/SONY_DCRTRV250__C3122_Reinsert_the_cassette_error-269771.html
8/1/2011 8:08:52 PM • Sony CCD-TRV238... • Answered on Aug 01, 2011
Hi. My camcorder wont play any tape for more
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
10/10/2010 10:08:47 PM • Sony CCD-TRV238... • Answered on Oct 10, 2010
0answers
Playback
if the camera is going on in the play mode and you are getting a blue screen with play indicator it is mostly due to dirty head. what have you used for cleaning the head. take the help of repairer for cleaning as he will do so after opening the cover. if that doesent solves the problem then get the video head checked for any damages such as broken tips.
11/18/2008 10:13:23 PM • Sony CCD-TRV238... • Answered on Nov 18, 2008
Battery
Dear Kishor Soni,
Your camera doesn't get information from terminal C of battery, thats why it gives such error message. Please check battery terminals at camera unit where you put/ install battery, aspecially C terminal. it can be rusty or dirty.
5/28/2008 10:34:40 AM • Sony CCD-TRV238... • Answered on May 28, 2008
PLayback of NTSC tapes
Hi, Not on the same brand/model but on another that is only PAL/Secam compatible. Video is squeezed top & bottom, black & white, high speed audio. Hope this be of some help/idea. Good luck and kind regards.
9/3/2007 10:12:10 AM • Sony CCD-TRV238... • Answered on Sep 03, 2007
Trouble with camcorder
try cleaning the rubber pinch roller with a cotton swab dipped in alcohol
5/26/2007 12:16:58 PM • Sony CCD-TRV238... • Answered on May 26, 2007
Sony Handicam TRV30 - Loose Lens
hi sounds like the screw that holds the ccd is gone but its inside you say it all works good....? put a SMALL!!! drop of "superglue" it will hold nice good luck
4/17/2006 9:59:24 AM • Sony CCD-TRV238... • Answered on Apr 17, 2006
RCA 8mm tapes shot in EP mode will not play in Sony.
There doesn't seem to be much information but I guess your Sony can only play SP (standard play) tapes? https://www.google.com/search?q=RCA+8mm+tapes+shot+in+EP+mode+will+not+play+in+Sony ..
11/5/2022 4:49:15 PM • Sony Video... • Answered on Nov 05, 2022
2answers
Rca 8mm tapes shot in EP mode will play in sony camcorder
Good to hear it.
11/5/2022 7:44:59 AM • Sony Video... • Answered on Nov 05, 2022
SONY CCD-TRV37 cassette compartment buttons doesn't work incluiding the zoom one, can you help me?
Your Sony is similar to this one. This switch has 3 positions. To playback and use buttons for cassette, turn the dial to VCR or it might be called VTR. image-e4f4ozhsscua0uhqzaix5g5v-d-0.jpg
8/19/2022 11:58:44 PM • Sony Video... • Answered on Aug 19, 2022
Sony DCRA-C121 play back tapes
Take them into a camera shop and ask for them to be put onto a memory stick in .mov format. Or buy one on the secondhand market, Facebook Marketplace, Kijiji, or eBay.
5/31/2022 12:25:14 AM • Sony Video... • Answered on May 31, 2022
2answers
C31 22 EN SONY DIGITAL VIDEO CAMERA DCR-TVR16E
Mechanism has failed. Take it to an Authorised Sony Camcorder repair shop.
5/27/2022 7:27:50 AM • Sony Video... • Answered on May 27, 2022
Sony CCD-TRV238 Camcorder Logo
17 questions posted
Top Sony Video Cameras Experts
Marvin
Marvin
Jaime Hernandez
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Video Cameras
  • Sony Video Cameras
Most Popular Question
sony trv128 analog camcorder displays
  • Video Cameras
