20 Most Recent
Sony Handycam DCR-IP5E Micro MV Digital Camcorder Questions & Answers
Hello! I'm using a softwer : movie shaker 3.1. for
You need to use DV Port in camcorder to transfer movie files into computer that must has same DV Port.
USB port can not be used to transfer movie files as its just to provide still picture data.
DV Port is maybe labeled as iLink in your camcorder so hook camcorder with computer with DV cable.
Hope this info will help you.
Thanks.
Part Number of the AV Cable for
I will forward a link to a page where you can get more information about this issue.
http://www.sony.co.uk/product/cac-cables---connectors/vmc-15fs
Please confirm whether you're looking for the same cable as shown in the picture on the page.
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
Blue screen on TRV260 playback
TRV260 nail-polish head attack:
eek.
Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation.
Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum.
Not to mention gumming up the bushes and bearings.
With your next camera, rather use a head-cleaner DV-tape.
Sony dcr-hc62 won't record
Memory stick could be fubar. I have a bad sd card that I can record to and will work. Then a few days later the data is corrupted, and I have to reinstall it / same pattern. Try another stick to verify that it is the stick and not the camera electronics.
