20 Most Recent Cyber Acoustics CA-2014 Computer Speakers Questions & Answers
Contact them again and also check your junk mail folder
Cyber Acoustics... | Answered on Dec 12, 2014
take note on the brand, and model of your camera then google the driver :)
Cyber Acoustics... | Answered on Jun 02, 2014
This is shooting from the hip since I don't know your operating system. Open the control panel and go to Hardware and Sound. Next, click on sound. You should see a device listed under Playback. If not then you are missing the driver for your sound card. If that is the case you will need to go to PC's manufacturer web site and download the necessary drivers. If this is not the case then you can go back to control panel under Hardware and Sound and under the first item is Device Manager. Open this up and check that there are no devices with a flag. If you do find one with a flag then open that category and select device then right click on it which will give you the option of updating the drivers. Hope this helps.
Cyber Acoustics... | Answered on Mar 03, 2014
hello,
I think you need all the drivers in the computer and not just the sound driver since you wiped out everything there.
Here's what you can do:
Go to the website of your comptuer's manufacturer and auto detect the brand of your computer. If they don't have it, then just try searching for it in the computer's casing. You should find the model name somewhere. Make sure to select the support and downloads page in the website and enter the operating system that your computer is currently running. All drivers will be shown on the screen.
Download the following:
1. Video Driver
2. Chipset Driver
3. Audio Driver
4. Internet or Network Driver
You should also install an anti-virus in the computer to make sure that you won't get any virus. After installing everything and if everything's working great, then you can other programs there. You can also add a tech software which can boost your computer's performance like RadarSync which will keep all your drivers updated.
David
If you have any questions, please drop me a line.
Cyber Acoustics... | Answered on Mar 09, 2013
Make sure the have the audio drivers form the computer you will need to find the drivers for the sound card if you will give me information for your computer such as make /model and operating system I can help you with that
Cyber Acoustics... | Answered on Sep 06, 2011
Please check all the cords associated with the speakers (the one to the computer, the one to the power outlet, ect) and make sure they are all plugged in correctly. Next make sure you have turned the speakers on, I dont know how many times I have thought my speakers were bad and I had turned off the power to them. Next in the lower right corner there may be a speaker looking thing, double click it and make sure you are not muted (can also be found in control pannel (sound and audio devices). Next try in the control pannel, and sound and audio. Make sure the output is set properly. I have seen some computers set to a digital coax out, when plugged in with a standard mini jack. If this is the case change the digital coax to the analog mini jack. Also make sure that it is not selecting only the front port.
Hope one of these helps
Cyber Acoustics... | Answered on Sep 01, 2011
You must confirm that they are plugged into the correct output and also into a power source. If they are powered speakers it can either be the audio out or the headphone jack, if they are not powered then they have to be plugged into the headphone jack. Next confirm the audio driver is correctly installed. Finally confirm that the system sound and the sound for whichever program you are using is not muted.
Cyber Acoustics... | Answered on Jul 14, 2011
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Cyber Acoustics... | Answered on Mar 26, 2011
you may need to check the sound card on your system if it is not showing up then you may need a new driver, or the volume is on mute
Cyber Acoustics... | Answered on Mar 20, 2011
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
don
Cyber Acoustics... | Answered on Mar 07, 2011
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Cyber Acoustics... | Answered on Jan 13, 2011
If the cable between the speakers are ok then it could be the speaker or the output in the master unit to the right speaker.
Cyber Acoustics... | Answered on Nov 18, 2010
1. Verify that the speakers are plugged into the correct jack on the soundcard.
2. Check volume on both the speakers as well as Volume properties on the computer. You may have mute checked or the volume turned down.
If neither of the above correct the problem, you may have an issue with your soundcard. Try uninstalling and reinstalling the driver. If all else fails, you may have a faulty soundcard.
Cyber Acoustics... | Answered on Oct 31, 2010
Did u check it with another computer.If it was working at that time then plz check whether the cable was loose while connecting to ur computer.And also check whether the audio driver is installed on the computer.
Cyber Acoustics... | Answered on Sep 11, 2010
Cyber Acoustics CA-2014 Computer Speakers Logo
35 questions posted
Top Cyber Acoustics Audio Players & Recorders Experts
Marvin
Marvin
Paul Bade
Muntejaya Ginting
Muntejaya Ginting
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Cyber Acoustics Audio Players & Recorders
Most Popular Question
need drivers
  • Audio Players & Recorders
