20 Most Recent
Cherokee 01 02 Town & Country 01 02 Voyager 01 Grand Cd Changer 7502 Questions & Answers
Can I find the radio code for a chrysler grand
To get this code generally you need two pieces of information
1) The serial number of the radio. (you will need to remove the radio to find it on a sticker - usually at the back of the case).
2) The VIN (Vehicle Identification Number) from the log book of the vehicle.
With this information you need to contact the dealer to retrieve the code from their database. Some dealers charge - some do not so it is worth ringing around to check this.
In some countries it is possible to retrieve the code directly from the license plate without the serial number of the radio but again this is dealer dependant and you need to check this directly with them.
If the information is helpful please leave a vote for it. Thanks.
Radeo needs code
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Please supply your radio MAKE+MODEL plus ALL the
NUMBERS+LETTERS on ANY LABELS , BARCODES or STAMPED IN THE METAL CASING
Also quote the make of car
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
