20 Most Recent Cyber Acoustics CA-3080 Computer Speakers Questions & Answers
have you installed the line filters as recommended
as adsl and home phone use the same line but at different frequencies , feed back is generated that the line filters remove
Cyber Acoustics... | Answered on Jan 13, 2018
either bad quality of preamp or the speakersistem has some probblems
Cyber Acoustics... | Answered on Apr 22, 2012
Double check your wiring again, sounds like something is either not hooked up right or maybe you got faulty speakers. There shouldn't be any hissing or humming in any speakers. Get a flash light and make sure you have it in the right spot on your computer most sound cards have about 5 different jacks you could have simply put it in the wrong jack.
Cyber Acoustics... | Answered on May 15, 2011
what operating system are you using you can download lots of sound drivers from cnetdownload.com
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Cyber Acoustics... | Answered on Mar 27, 2011
also
you might check
hope this helps
don
Cyber Acoustics... | Answered on Feb 23, 2011
Double check that you have the lead wires connected to the properly sockets.
Next, make sure the speakers aren't too close to some other electronic
device that could distort the sound.
Cyber Acoustics... | Answered on Nov 26, 2010
You mean at the back of the computer? You will find a standard 3.5mm jack(headphone jack). You should plug it in there. Usually has a green colored circle around the port.
Cyber Acoustics... | Answered on Nov 04, 2010
it could be a connection from not grounded to your aux cords being crimped and messed up could be amp or could be a setting on your radio..
Cyber Acoustics... | Answered on Feb 13, 2015
Crackling noise and cut outs generally mean that the speaker is torn, or the cone is separated from the driver. This means the speaker is broken irreparably. It sells for $40 now, which means it is not worth fixing. These low cost speakers are built to not be taken apart.
Cyber Acoustics... | Answered on Apr 07, 2014
Cyber Acoustics CA-3080 Computer Speakers Logo
Popular Tags
13 questions posted
Top Cyber Acoustics Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Muntejaya Ginting
Muntejaya Ginting
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Cyber Acoustics Audio Players & Recorders
Most Popular Question
interference coing thru speakers
  • Audio Players & Recorders
