20 Most Recent Cyber Acoustics CA-3090 Computer Speakers Questions & Answers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to re-install drivers
cnetdowload.com if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html
http://www.freeware-downloads.com/soundmax_integrated_digital_audio_driver_v.htm
SoundMax Integrated Digital Audio Driver v hope this helps
Cyber Acoustics... | Answered on May 16, 2011
also
hope this helps
Cyber Acoustics... | Answered on Mar 15, 2011
  • Check the sound control software settings in the computer. Somebody may have turned down the sliders below 2kHz on the software equalizer (possibly a third-party program, not necessarily the original Microsoft Sound control panel settings).
  • The woofer may not be working. Check to make sure it is properly connected. If it is, try unplugging the speakers from the computer, turn on the speaker power and turn the volume up about 1/4. Touch the tip of the plug that goes into the computer with a slightly dampened finger without touching the ground ring next to the plastic barrel. You should hear a hum from the woofer and possibly one of the smaller speakers. If not, there is a problem with the speaker amplifier. To check the other speaker, repeat the test with the middle ring on the plug (hold something metal in your hand to touch the ring if your fingertip is too wide to touch it without also touching the ground ring). If you can't get a hum, there may be a problem with the speakr amplifier.
  • Another possibility is a failure in the computer sound circuit, such as a coupling capacitor between amplifier stages or at the output. However, this would probably affect one channel much more than the other.
Cyber Acoustics... | Answered on Dec 31, 2010
your volume knob has some carbon depsoits possibly try removing the cover of knob, clean with thinner or ether.
Cyber Acoustics... | Answered on Mar 09, 2010
that happens to me all the time after a while the sound turns off and you have to reboot tthe system to make it work again
Cyber Acoustics... | Answered on Jul 22, 2009
You have a short/open in the cable (power) intermit. Move the cable around and see if the problem gets worse. rewire or replace
Cyber Acoustics... | Answered on Mar 05, 2008
the movement to another place was not the cause of lost program. you just have loose contact, try to remove the sound card then clean then reinstall if you have. if you are using the on board soundcard, check your phone jack if you inserted to the correct one. green is the default and pink is the microphone's default
Cyber Acoustics... | Answered on Dec 22, 2007
it could be a connection from not grounded to your aux cords being crimped and messed up could be amp or could be a setting on your radio..
Cyber Acoustics... | Answered on Feb 13, 2015
Crackling noise and cut outs generally mean that the speaker is torn, or the cone is separated from the driver. This means the speaker is broken irreparably. It sells for $40 now, which means it is not worth fixing. These low cost speakers are built to not be taken apart.
Cyber Acoustics... | Answered on Apr 07, 2014
Cyber Acoustics CA-3090 Computer Speakers Logo
Popular Tags
13 questions posted
Top Cyber Acoustics Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Muntejaya Ginting
Muntejaya Ginting
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Cyber Acoustics Audio Players & Recorders
Most Popular Question
speakers work but no
  • Audio Players & Recorders
