20 Most Recent Cyber Acoustics CA-3000 Computer Speakers Questions & Answers
the speaker has a partially burned out capacitor. Unless you're really handy and the value is worth it I would replace the component and not the whole board
Cyber Acoustics... | Answered on Feb 07, 2018
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Cyber Acoustics... | Answered on May 04, 2011
You may not be able to get an exact original replacement. Most of these systems were never meant to be repaired, just replaced. You can try searching online; there may be a source already identified. You could also try eBay or some other auction site to see if anybody is selling one of these systems. It may not be worth trying to repair yours, though. Amazon.com is selling the system for under $30. Buying just a replacement speaker may cost that much, plus your time and labor to install it.
If you really want to try repair, a good source of replacement speakers in the US is Parts Express. (I don't know if they ship internationally, I've never had a reason to check.) They may have something available that will fit the cabinet. If they don't, or you're in some other part of the world, check online for speaker vendors in your area.
Good luck with your hunt, and thanks for using Fixya!
Cyber Acoustics... | Answered on Oct 17, 2010
This is all i could find
requiring 9VDC 500ma power .... Cyber Acoustics Studio CA-3000WW Multimedia Speaker System
Cyber Acoustics... | Answered on Aug 03, 2010
this a problem with the loose connectin in the jack i think the soldering has gone off or there is a breakage in the wires if it is still under warranty then i suggest u take it to the service guys
else just cut the wire a lil away from the jack and get a new jack soldered n things would be back to normal u can get this done in any radio shack nearby
Cyber Acoustics... | Answered on Jul 27, 2009
if the sattelite speaker drops several times. i thing the filter of the speker are broken or the magnet of the speaker are separated from its coil. thats why they dont work... that mean you must replace a new sattelite speaker
Cyber Acoustics... | Answered on Feb 20, 2009
Hello cv21
Happy holidays
well, try to see if any back cable on computer is lose. depending your Operating system, go to your sound mixer on software, and see if volume is enable, and not in mute position, and all, other sound are up .
reconnect again your speakers to your PC,
good luck
Cyber Acoustics... | Answered on Jan 25, 2009
Hi , open the control panel /select to classic view,select add hardware to locate some drivers cyber acoustics speaker just follow the instruction to connect the speaker.
check also the device maneger the connection of the device.
Cyber Acoustics... | Answered on Jan 12, 2008
see there is power on speaker and check the audio cabe connection is it properly connceted to audio jack in your sound card. bye
Cyber Acoustics... | Answered on Sep 24, 2007
Cyber Acoustics CA-3000 Computer Speakers Logo
18 questions posted
Top Cyber Acoustics Audio Players & Recorders Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Muntejaya Ginting
Muntejaya Ginting
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Cyber Acoustics Audio Players & Recorders
Most Popular Question
lost adapter know need 9 v dc
  • Audio Players & Recorders
